Shimano TN 30
Hooked
I bought this TH30 about 13 months ago.It has seen a lot of hard use and has not molly coddled.
It has had quite a few mods and repairs including :
Carbo Tex Drag Washers ( Worth every cent )
Better Bearings ( I go through them like I go through sinkers )
New modified anti reverse gear ( not so keen on this )
Line out adjuster removed
Spool pin pulled ( good trick )
New Dog Tooth pawl
New ARB
Star drag clicker removed ( I hate that thing )
Here is a bit of a summary about what I found when opening the reel.
Modified anti - reverse gear:
Dont go here.The plate is thinner than the standard and doesnt seem to be made of a good enough steel.On my one the plate is already developing grooves on the flat side where the pawl guides run and the teeth are starting to round off already.I am going to order a new OEM part and put this one in the spares bin for now
Hooked
Drive gear :
Showing some wear on the under side .I polished off the worst with some water paper on a piece of granite.SStill good as new apart from this , all teeth 100%
Hooked
I have no idea what this part is called but I am pretty sure that it's not supposed to be oval.This is probably caused by having the end cap too loose
Hooked
I have arriving tommorow some new ABEC 5 bearings , Cals drag grease and a new anti reverse gear.The reel is in pretty good mechanical shape and has stood up well.It has landed well over a ton of fish now and will be good for a long time still.
I have taken to working on the reel myself cos Whale Boy said I wasnt to touch it cos I would stuff it up and I do like to rev him up...........hahahahaha
The carbo tex drag washers are around four months old.Landed 8 bronzies on them and they show no signs of wear.They are just getting re-greased and put back in.I have tried other solutions for drag washers and these seem to work the best for me.
Hooked
[color=#ff6633]Nepptune[/color] wrote:
Two words for you and your camera skills Hooky ..............
"MACRO SETTING"
Sorry dude , I didnt buy the camera at Macro so they wont set it for me :hyst:
Two words for u and your Macro settings , first one starts with an F and the second word is Off :hyst:
Thou shalt pay dearly for critisising my camera skills :fbash
Whaler
with good reason! i have seen you in action! hooked phones me up and says there are some parts lying on the floor where he has just built his reel, would i know if he could fit them later as he needs to go fishing!!LOL
Hooked
True but they were not really needed.........
surfaMIKE
Hahahahahahaha:hyst::hyst::hyst::hyst:
Thats something i would do with a repair job on my surfboard
rofflign
my torium 30 is also about a year old now,fitted carbontex a month ago (they're awesome),the standard washers were breaking up!!only other wear and tear is on the drive shaft bush,which i'll replace with a bearing.In contrast my 12yr old penn555 has the original drag washers and wear and tear is virtually non existent....go figure,still prefer the torium though for it's casting ability.
Hooked
Trini is all sorted and ready to go.Re greased the washers and put in the ABEC 5 bearings and it feels like a million bucks
