Shimano Exage 1468
Tjooona
Hi guys,
Bought myself the above mentioned rod yesterday secondhand, looks brand new...
I've tried to assemble it but it's close to impossible.. the second part just won't fit all the way...
Is there a easier way or quick fix to make it fit easier without potentially breaking the rod..
I'm a big oke, power is not the problem.
PatrickC
Whats not all the way in? I've had two exages and neither of them have fitted together up until the glossy coating starts usually about a cm sticking out.
PM Engima though he is the rod guru. Saw a thread recently where there was a discussion on using fine sand paper to get the right fit.
Tjooona
Yeah, all the way until the glossy part start... if it's even meant to go all the way??
Mines also sticking out about a cm, this wont create a weakspot?
PatrickC
Never had a problem with mine, it sits tight and no rattle.
I'd be concerned if it felt loose in the joint when not going all the way in.
This is just my experience though. I'm no expert.
Chat to Engima
Johnny Blaze
i little fine sand paper would do the trick...what does the previous owner say on the matter? I bought a exage once and the guy not knowing took his buddies tips from a different exage...only discovered afterwards and prevented lots of frustration of parts not fitting.
