Shimano Exage 1446/1468
Scorp
Good day all
I have ran a search for related topics, but couldn't find anything with relation to my question.
I have the Exage 1468 with the 3 interchangeable tips, and wondered whether the 3 tips of the 1446 would work on the base of the 1468. The heavy tip of the 1446 should then be the light tip of the 1468. If it is in fact the same base used for both the 1468 & 1446, I would like to get just the tips for the 1446 to be used for my lighter applications when targeting smaller eds.
Could any fellow sealiners which might have these rods or have done this, assist me with some advise. Thanx
Tight Lines, Scorp
200ts
Hi, it sounds logical. probably will work but i would check with the rod builders anyone on sealine that can help?, cause it might affect the balance but im no expert.
Scorp
Thanx 200ts. I have done some enquiries at tackle shops about this and nobody can really tell me. Logic tells me that it should work, unless the graphite composite is different in the two rods. I am no expert and therefore asked the guys on sealine.
Please guys!
Thanx
kitefisher
Scorp, this is purely guessing,but my gut-feel tells me that the 1446 will have a "softer" midsection as well,posibbly even a softer base.Like I said, this is purely guessing,but what I'm trying to get at ,is that you may be dissapointed in the action of a 1468 with a 4 oz tip in,moreso if the manufacturer specifically matched these tips(4,5and 6oz) to a softer midsection and/or base.
Your findings will be interesting and I think any dealer that stocks both should be able to let you interchange tips and mid-section just to satisfy your curiosity.
My personal opinion would be that if there is not a substantial saving in buying only the tips,then two rods would always be better than one,irrespective of the amount of tips.You may want to leave your slide/in-ed bait in the water and scratch around with a second lighter rod if conditions allow.
Keep us posted.
Pylstert
Unfortunately they don't fit, the mid section is definetely thicker on the 68, this was on the old model, not sure about the new model. Any case even if it did fit don't think it would really work all that well
Scorp
Kitefisher, Thanx for your input. I had the same gut feeling and was a bit worried about the action I would get with the 4oz tip. The mid and butt section of the two rods would probably differ, but I've got this feeling that most of it will have to do with the tips. Could be horribly wrong as I am no expert.:fbash
Mostly curiousity that fuels this topic.I have another 14ft, and a 12ft custom which I use for scratching. Just thought that if the tips would work, it would be nice to take the tips with my 1468 and use the 4oz tip for some lighter applications when only travelling with one setup.
Would like to try the lighter tips on the 1468 to see what the action will be.Will keep you guys posted, as this could be quite interesting!
Cheers, Scorp
kitefisher
Scorp,just in closing,you may be pleasantly surprised at how well the 1468 handles a 4-5 oz lead ,give it a thump with maybe just a smaller reel.Although even your 20/40 size with maybe .40mm line will make you realise how versatile an entry level rod the Exage 1468 actually is. Entry level is probably an insult to this rod as it is only entry-level insofar as price is concerned.
Some huge fish have been claimed on this forum, to have been caught on the 1468.
camo shorts
I snapped the middle section of my 1446 (new spec) and considered replacing with the 1468 (new spec) mid-section which fits into the 1446 base, but no luck with the tips.
kitefisher
Camo Shorts
Thanks that clarifies my suspicion,I would guess again that its thinner at the top of the mid-section than the 1468. Btw how did you snap the mid-section and where did it snap if it was during normal usage/
kitefisher
mikesfb wrote:
could i do the oposite and put the 8 or 7oz tip on my 1468
Mikesfb,do you mean your 1446 ? Whichever way,I know that anglers should always innovate,yet I think in this case we should give the manufacturers enough faith i,n that these two rods were intended to be different ,and it seems that they are just that.
Scorp
Good Day all
First of all I'd like to thank all who replied and gave some input on this thread.
@mikesfb, unfortunately you will not be able to use the 8oz tip on the 1446 as the mid-sections of the two rods differ.
I managed to get my hands on a new 1446 and went out yesterday to do some experimenting, and would like to give you guys some feedback. I took the 1446 and my 1468, together with a sl30, sl50 and a 20/40 to the beach for an exstensive casting session.
@kitefisher, First I took my 1468 with the sl30, the light 6oz tip and a 4oz sinker, to see how the rod would react with a smaller reel and sinker as kitefisher suggested. I was quite surprised, and managed to thump the 4oz quite a distance. However the 6oz tip was a bit stiff, and I had to really push hard in the cast, but it is do-able.
Then I switced to the heavy 8oz tip with the sl50 and a 8oz sinker. Did some casting and then started to push the limits by going up to a 10oz sinker. Was a bit scared but the blank loaded nicely and handled it with flare.
Then started the experimenting, I took the 1446 with the heavy 6oz tip, the sl50 and a 6oz sinker and did some casting. Then took the 1468 with the light 6oz tip, the sl50 and a 6oz sinker, and did some back to back casts with the two outfits to feel the difference in the action of the two rods.
I managed to get a further distance with the 1446 as with the 1468, as I expected as the 1468 is a bit stiffer. The 1446 blank felt like it was almost a bit overloaded when I really pushed hard during the cast, but resulted in a nice whip action in the tip and sent the sinker flying for miles.
My personal opinion is that the 1468 might be a better bet, as you can go with the light tip and a smaller reel and sinker, and use it for lighter applications, and then push the limits with the heavy tip and bigger reel and sinker for those sliding sessions.
As kitefisher said, its a very good all rounder at an entry level price, and I'm glad that I decided on the 1468 a while ago.
All and all, I had a blast experimenting and in the process managed to do some casting practice. Hope this information will help some fellow angler out there.
Tight Lines! Scorp
