Shimano 15/30 conversion possible
grootvis
It seems that the 15/30 and old speedmaster TSMlll are the same size, is this correct. If so, can the drive gear and pinion gear from the TSMlll be put into the 15/30 to increase the gear ratio to 6.0:1?
Can this be done? Any comments?
Joker
Yes,they are the same size. That's the 15/30 & the TSM3. Both lovely. Uncomplicated reels.
All the parts you mentioned can be interchanged.
grootvis
Thanks for the replies, just one thing though, is the TSM lV also compatible as I think the parts for the TSMlll might be hard to come by.
Joker
As far as I know, yes. The internal parts can be used in both reels. Even the side plates can be switched around.
