Cover the blade with hose pipe or any pipe that will cover the bare blade to prevent cutting yourself when rummaging in your tackle box i.e insert the bare blade into the hose pipe.
thanx for tip..and if storing your grab sinkers and scared to poke your fingers when looking through bag then simply cut up a straw into pieces about 3cm long and insert steel legs in there and voila problem solved cheaply
