Shad - Running Trace vs Fixed Trace
djvip2000
Hi
I am curious to know which trace is betta to fish with.  I have both types of traces but when I hit the surf I just dont know which would be a betta option.
Help out guys.
Also what length should both traces be. includind sinker length.
Dorado75
I personally use a running trace for most fish, especially elf and Kob, hook trace normally longer than the sinker trace. Reason been is that when the fish picks up the bait it does not pull against the sinker and then drop the bait!
Moss
We fish velddrif alot for shad and we use a sliding sinker rig. A bit of foam on a long shank hook. Works for me
BigBass
I really think the notion of fish dropping or spitting out the bait because they feel the sinker weight is perhaps more imagined than real ...
I always used to fish with a sliding sinker in surf and freshwater. But not anymore ...
Recently I changed to the Pulley Rig in the surf and have been more successful using this rig than ever before.  Do a search on SEALINE or look under "Rigs".  As I am currently fishing predominantly in KZN I have not yet hooked White Steenbras on this rig, but it is pure magic on other species (especially Kob and Rays). No reason why it would not work for Shad too ... :wfish
I was a bit sceptical at first when trying the rig - concerned about the fish feeling the weight of the sinker too soon and perhaps rejecting the bait, but this does not seem to happen. I have had success on each occasion while using this rig. Some plusses are: that the sinker will not easily get stuck on rough ground as it is lifted when a fish in on; the fish really do seem to hook themselves, especially when using circle hooks with this rig; and the trace and sinker line NEVER tangle or get wound up around each other as one often finds on conventional rigs when the current swirls ...
Also consider Carp fishing and the success of rigs such as the "Mealie Pip Trap" which employs short (10cm) fixed sinker and hook traces. The Carp invariably end up hooking themselves and belt off on reel screaming runs ... and Carp are supposed to be extremely sensitive and intelligent fish! ;)
If your hook is sharp and the gape and point open and proud (as it should be), you may probably be putting yourself at a disadvantage if you use a sliding sinker :shock: (unless, of course, you have a swivel or stop so that the sinker slams home the hook after a short free run!). :)
The sliding sinker plus swivel stop method is apparently great for White Steenbras ...
Just a couple of thoughts and experiences which may challenge the conventional "wisdom" of sliding sinkers ...
Anyone out there with similar experiences?
AnglerX
Bigg Bass
Had similar experience with sliding sinker, fishing for shad and monster kob picked it up, swam at 90degree angle to sinker wich got stuck and almost burnt me of on the swiwel before sinker line could break. No using the swiwel stop method and works great on the skittish and shy biters, the "sliding section" between the two swiwels must be as close to 1m as possible  the drop will be longer than usal but you come right with the cast after a while
