Hi all,
I need a bit of advice regarding my Saltist 50, been battling to brake the thing correctly when casting, so I'm pretty sure the spool tension is too loose.
I've been told to set it using a 3-4 oz sinker, disengage the spool and when the sinker hits the ground, the spool should stop turning. Anyone else heard this?
Another thing, I'm still not 100% proficient when casting the reel, but not sure if 2 brake collars on each end are too much, any advice here?
Nou maak jy n groot fout!!!
:first
