I'm not sure how tight the drag should be set on a baitrunner reel. When the drag has been set relatively loose, i've had a serious run and an overwind on the spool. (chaos when using braid). On other occasions the drag has been set a bit tighter and the run is but a few seconds. I have lost a few fish under both circumstances. Does the weight of the sinker play a role in any of the above scenarios.
