servicing a torium 30
Volcom
Diawa Lube on a Shimano product? lol, just kidding man....
Yea its k i guess but Rocket Fuel works better.... thinner visco and better casts...
Darren... my 2c worth... from previous threads, some of the guys say that if you wade or get your reel wet, Rocket fuel doesn't last long at all. So you need to be careful when using it. If you use Rocket fuel, then the gist is to lube your bearings after every session!:shock:  It was originally designed for the distance casting competitive guys, who do lube their bearings after every use.
What I do is use a fully synthetic oil, such as Mobil 1 motor oil (which was the best oil ever invented). Its quite expensive stuff, but your bearings are gonna last forever. They used Mobil 1 on an Isuzu engine and ran it for 1 million kms - the inside pistons and goodies were still factory spec! Mobil 1 is quite difficult to get hold of though..?
A lot of guys use PROLONG. A trick is to heat the bearings in a teaspoon (after you've soaked them clean in benzene) and once they're nice and warm... whack them into the prolong, it apparently sucks in the oil like a sponge! Apparently, guys spools spin for 3 minutes when doing this....
Hey darren..reefman is quite on the money there!! Use his advice on the prolong and u wont go wrong! Rocket fuel is avail in a red label and yellow label categories but either are not suitable for normal fishing use! It costs about R50 to R70 rand depending where u buy it from...
Alternatively i see u in durban...take your reel down to tackle centre in old fort road, for around 65bucks u can have a proper service done by the professionals....kevin from there is an absolute master!!! Get it done by the best and it will work perfectly!...hope this helps....
mumro
how often does one have to service there reels?Here in jhb servicing costs around R80 to 120....now if you have 3 reels?i also wanna service my own reels.....are there any gurus that can give us a breakdown on how.
Mums, I'll try put something together... but it will take a while....
I love the technical aspect of these things and taught myself how to do it...
What I did the first time I serviced my reels... Keep the Schematic diagram and a digital cam handy and take picks at every different angle and at every step of the way. When you get back to putting it together and you get stuck... just refer to the fotos - it worked for me!
I also got hold of some benzene - dumped all the parts into benzene for an hour - wow! do they come out sparkling clean - all the old grimy grease GONE! Was able to really clean the reels well and grease them up, oil all the bearings properly... there's NO WAY a tekkie will give my reel the same love that I do!
One word of warning... be careful with the Coffee grinders... it just seems their mechanics are so much more complex... scary stuff!
Land Locked
Reefman,
The coffee grinders I've done have all been a piece of cake. Please send schematics of those that gave you a rough time.
LL
I'm talking about the bale arm and stuff - my Shim Nexave has springs and all sorts of scary things inside it!
Land Locked
Reefman,
Now I understand.
If you really want a kak thing to try n repair, with spring n levers and all that small stuff, let me send you a common or garden ignition switch.
LL
mumro
thanks reef will really appreciate it.....i have to many casting reels if i service them all ill be broke....i have 2 shimano calais,2 shimano sf,1 curado,1 cronarch,1 corsair,1 saltiga,2 trinidads...the list is endless:breakd:
mumro
howzit guys
ive been talking to a few guys regarding reel servicing....they use parafin to clean the insides of the reel,basically a degreaser.....some guys use a mixture of benzine and parafin....but i got some advise from another site......
"It is not a good idea to use chemicals on reels and this is why...The use of harsh chemicals such as gasoline on plastic parts in reels may not show up until later. The chemicals can corrode parts. Use of a bio-degradable cleaner is highly recommended to clean reels and parts"
all the guys out there doing there own reel servicing is this true?:?
