Cuban Cigar
grootvis wrote:
:lol:1Cuban Cigar wrote:
Hi grootvis !
My own "MAG-IT" Trini 16A is fully loaded with the "old 30lb" Fireline which measures between 0.36-0.38mm diameter and is way nearer to 100lb than to the originally claimed 30lb.
I rigged it like that with a two rodlength 0.60 Maxima leader, specifically for steenies and can see no reason, why the reel can't do double duty for you there !
If you feel the need for a thinner diameter leader for the steenies (less side draught in rips & current), you could simply and quickly, remove the leaser and replace with a smaller diameter one. made up from clear Berkley Trilene Maxx, which offers a bit of shock absorbing stretch and awesome braking strength vs diameter !
Remember to check for stock with Mark in PE, before taking in your reels.
Cheers !
I made a mistake it will be 60lbs. Nah, I don't like using the reels for 2 different applications. You know me, full of the brown stuff at the best of times. Things have to have their place and perfectly optimised....![]()
