Sealice Prep
Volcom
Hi guys,
A while back some of you were asking how one would pin a sealice. While many have their own versions, iv been launching these lil guys a good couple of metres using the below mentioned way. Another plus is that it looks natural, the gape of the hook is exposed and no cotton is needed. Great for hooking onto a sinker and letting rip to a farrrrr bank.
Volcom
Firstly, I normally use a 5` Diatchi, perfect size for edibles.
Volcom
Flip the scraper part of the sealice up, exposing the underbody.
Volcom
Insert the hook just above the set of legs. Try not to break the sealice up when doing this.
Volcom
When the hook is at the front end of the sealice, turn the hook around so that the start of the gape sits snug against the harder part. (between the two sharp points)
Volcom
Finally you have the perfect bait to take on pretty much the bulk of edibles (and flatties) found along our coast.  Tight lines!!
sharkbyte
Heres a question do you get these see lice down here in the southern parts ? between Cape Town and PE? if so where and how do you catch these buggers.
Volcom
@ Weeds and co????
Catching Bob is pretty easy. Just watch for his feelers which form a V in the sand. They whip theses through the passing water to get their tums full. Simply wait for the water to receed and then dig in. The part u see sticking out is indeed the FRONT part of Bob. The scraper is located at the back end. Area of note is course sand with hardly any shell grit or stones. :dude:
Now THATS the way to show people how.... excellent post Volcom, thanks for that. Good Pics make all the difference.
We went to Xai-Xai last year. You should see those locals catching sealice. Its amazing how they've mastered the trick.
There was one local in particular by the name of "slimbliksem". If you ask him to catch you a couple, he would strip down to his undies. He would then leopard crawl to the spot where he last saw some sealice. When he is about 20m out he will jump up and run to the spot and start digging. What he does, is he put his feet together and every scoop of sand with his hands he will throw ontop of his feet (this all happen while he is standing in the water). If there is a sealice within the pile of sand, it will dig down and he will feel it with ontop of his feet. He mould then grab it and put it into his mouth. Very funny but extremely effective. He would generely catch up to 7 sealice at one go. And all goes into his mouth.
I tried this teqhnique several times at the amusement of my cronies and didn't manage to get a single one.
