Saltwater proof reel
Jannus.
I mostly fish off a jetski, which means my reels get a continuous spray of saltwater on the way to the fishing grounds.
I have had a Daiwa Opus Bull, and a Penn Battle. I believed both to be expensive, but both started jamming after less than a season of use.
I always rinse my reels with fresh water after use and I even oil them as well, but they keep perishing.
What reel could I buy that would withstand salt better? Because I am seriously considering getting a KP/Scarborough that has no mechanical rustable parts.
IWyk
Such a reel does not exist. You need to open the reels and give them a proper service and lubrication after sessions where you know they got wet from salt water to make them last, no matter the price you paid for them.
KP have a 7 1/2 inch reel with a drag that has been specially designed for fishing ski's. All KP's however also have bearings on the main shaft so they also need to be opened cleaned and oiled but this is much easier than a grinder.
Also pack the gearbox with grease for heavy salt use, I just have mine serviced regularly.
My shimano spinners, finnor lethal and penn battle have seen lots of boat time and a bit of kayak time, battle did have a gear die due to corrosion but it is up and running again and have a spare gear this time. Shimano's and lethal are in great shape with a rinse post fish and regular servicing by a pro and me just oiling the line roller.. as boat or no boat that bearing gets a lot of salt.
The finnor offshore spinner is also a reel that you can look at, not much to go wrong and stainless gears if I can recall mine had, had one but gave it to a mate as it was redundant with the gear I was given as gifts. My shimanos are not the ones for dunking but a spheros or saragosa is sealed for the task, just service before use and pack the gearbox with a good marine/corrosion blocking grease..
Spinners and kayaks offshore are not really a winning combo, but simple is best I reckon.
Buy a Shimano Stella or Daiwa Dogfight both in the R8000-14000 price class. They will last longer as they are sealed etc, etc.
You HAVE to Service your reels, just rinsing won't cut it.
Having spent that amount of money you will take the time to service them.
First bearing to seize up is the anti-reverse bearing, in average priced reels these are not sealed and cannot be greased or they won't work.
If this doesn't appeal to you then switch to multipliers that have no bearings ie Penn 500 Jigmaster or Shimano 15/30 or 20/40
Essentially the reels you have require double the service effort as your ski does, I'm sure the ski get's it's regular service and the motor is flushed before storage and all the necessary oils and lube are used.
Fredster
hi there,
I do the kayak thing alot, and have been for a while...
As has been said preventative maintenance is #1... pack the insides with quality marine grease, before the first use. Wash with fresh water after every use with teh drags tightened, and store with drags loosened. bit of tackle spray and oil the line rollers, bail & all handle pivot points. Bit of a strip and service once in a while, once every year or two...
Thats what i do anyway, and it works for me in terms of being effort vs durability.
The reels that have been good to me...
older spheros's, the FB i think (the one before the current new one), if you over grease the gearbox, the grease works its way up and starts making teh AR slip occasionally, but you just need to clean it and its all good again.
Finor Bahama, lekker solid all metal reel, thick main shaft.
And if you are buying new right now, the winner would be the Okuma Azore
All of the above reels have done very well for me and caught alot of geelbek and some bomber yellowtails.
As a strategy, if you are buying reels, its not a bad idea to get and use multiples of the same reel rather than have all different reels - years down the line, if you start having failures, and parts may be an issue, one of the reels could become a parts donor allowing you to at least keep one going and teh broken one isn't a total loss.
Psy
((goodp_ Fredster.
I posted some information on another thread some time back...here it is again;
Important simple yet pertinent information from a well know tackle Guru Mr Alan Hawk.
http://www.alanhawk.com/blog/care.html
::tight:::tight:
Excellent reply Fredster.
One part of any of the reels, including the Stella that cannot be protected from saltwater use and that you should regularly open and lube is the Line roller bearing.
This bearing is tiny and seizes or even jams with salt and sand deposits inside it.
Undo the bail arm retaining screw and give a liberal dose of Reel-X or Corrosion Block
EugeneC
The ultimate reel for what you have in mind is a bail-less Van Staal. Check out skishing and you'll see what the reels can handle.
On another note though, I have a Saragosa that went swimming 2 - 3 times a week for more than a year and, apart from the scratches on the body, you wouldn't know the reel's been used. The internals are in perfect shape. As many have mentioned here, pack the reel with grease, rinse in fresh water after fishing and spray with tackle protector after every outing.
You are lucky on your Gossa. I have a heap of anti-reverse bearings that are trashed as well as had 4 of them that are totally destroyed. Guys used them to fight fish whilst wading, water gets in and stays in and after 2-3 weeks with a saltwater filled reel the reel seizes completely.
