Saltiga spool cracking!
shane24
remlin wrote:
Hi guys
I have owned a trini30 and have swopped it for a Saltiga30 surf.I must say both are excellent reels but my personal opinion is that the saltiga casts way better than the TN30 which allows for more distance.Just waiting to get my hands on a Saltiga 50.
As Ray said, alot of people have their different preferences.
keep in mind that the tn30 and saltiga30 are different size, trini 30 is similar size to the saltiga 50, smaller reels cast way better than bigger ones therefor the saltiga 30 will cast better than the trini 30.
ants
We all know what these reels cost... I do a lot of research before I buy and If there are concerns about certain aspects of any reel I do take note of these and it does influence my buying behaviour. In Afrikaans there's this saying: "Waar daar n rokie is is daar n vuurtjie." When I started targeting sharks my first choice was a Saltiga after watching a couple of episodes of ESA. I then did my research and found that it was not just the spools. Anybody else had their frame crack when tightening the screws?
remlin
I have casted with a friends Saltiga 50 and it also cast way better than the TN30.I even feel that the Saltist 50 casts better than TN30.Just my opinion tho cause i'm getting way more distance compared to the TN30.Don't know whether it's a "all in the mind thing" that is why.
Friknam
The frame cracked because there were excess grease oil in the threaded hole when the screws were tightened. You can crack a train diesel engine block the same way. It is in no way a sign of an inferior reel.
Diamond
Banned
Ouch!!!
Diamond
Banned
So I take it you were present when this happened?
On another point .....I don't think the Saltiga would take as much flak if it wasn't so overpriced!
Friknam
Nope, but if you read Alan Tani's report on this you will get the same answer as it was him that cracked it.
Diamond
Banned
I have not read his report on this. If it is fact then I retract my sarcastic remark, please accept my apology.
TOE 007
its not the size of your worm , ITS THE WAY YOU WIGGLE IT !!!!!!! LOL :headb:headb:headb:headb:dude::dude::dude:
surfaMIKE
I can understand why some anglers would be reluctant to buy a saltiga, even though the spool problems were sorted out. Once bitten, twice shy? Anglers would be a bit more hesitant of buying one, because they would know about the past spool problems and wouldnt want to spend a small fortune on a reel and still have the thought in their head of: "will it break, will I lose my fish of a lifetime? I know the spool problems were sorted out, but what if I got the older model? The dud model?"
I know the spool is now alot stronger and wont pop as easily, but alot of anglers cant afford one, and so knowing there have been problems, wouldnt want to take a chance
Would I buy a saltiga? Yes, if I had the money, but for my fishing style all I really need is an sl30 or even an okuma multiplier
ONDE ONDA
Different strokes for different okes
I own both ranges of manufactures reels Daiwa and Shimano. From Sea line to Saltiga , Torium to Trinidad dc.  (Sounds like the DAKAR Race) maybe it is in reels! both of these manufactures wants to be on top log and in both cases excellent quality. But will differ to personal choice and color (Raymond I agree gold Trinidad not for me to) with positive criticism we get the best from the manufactures believe me they look at this. I own a Saltiga now for 6 to 7 years and have not cracked a spool on one of them and I have 4 of them. however I think there is one golden rule we all miss when  I catch a fish that  puts extreme  pressure on your reel , I always unspool the reel on to a another reel and  re-spool  the reel  when the braid is dry. I do this to relive the pressure from the reel.  you will never crack or brake a spool (on my older reels Penn 49 and 49A we put a layer of insulation tape at the bottom of the reel to take up pressure, not to crack the (Bakelite)   spool and I re-spooled them to after you catch a hefty fish and never broke a spool on a pen) (Don’t spool wet Braid). And to my opinion you can break a Shimano spool as well, if you don’t look after it.  Nothing is idiot proof
Daiwa virtually indestructible machined out of a solid high grade aluminum block and you get all of the stainless steel bearings, and good gears and drag system inside (build like a Sherman tank ) looks great and the new model a spiffy blue handle  a reel that should outlast my Pen 49
Shimano Trinidad DC (better color silver  this one for Raymond) extremely strong reel as well, the forged side plates,  looks a bit tinny but nobody land a fish on reel side plates , inside the reel is where  it now differs from one to a another,  the drag feels for me better  on the DC then the Saltiga (Maybe because it is new ) the retrieve ratio is better than the Saltiga and now the  reel  is with electronic dc braking control (cast in to the wind and don’t get over wind if reel is setup properly. you don’t need a educated thumb and you don’t sacrifice distance in a matter of fact you increase distance,  this reel is a must for the vaalies  can you imagine a vaalie without a over wind.  sorry vaalies  I was there to.
Shimano at this moment is better for me  with technology improvements. Tomorrow Daiwa might bring out a new improved model (Daiwa AC) that cast a mile. The main point of this fishing form is debate. (it would be boarding if we all supported the BULLS).  and if it your reel fails you send it in you paid a lot of money for it.
Thanks for all your input,  lekker fishing to all. And I fish with both models no problem.
FREE THE FIGHTER
Drag upgrades/fiddling with drag stacks or for that matter thumbing the spool can lead to more pressure than spool designed for and problems with very heavy lines - spool/AR bearing failure. Applies to ALL brands.
Saltigas excellent reels IMHO ( and so are Stellas)  - blondes or brunnettes ? My gripe as is Nepptune's,  why no jigging overhead reels (Z40, ST30T etc)  in SA. But then, maybe  no point in bringing them in if you are always gonna be trailing in the wake of the JM PE series ?
