Saltiga 6000 Surf
Trevelly
I just got my Saltiga 6000 Surf. I need to know what line to put on. I'm going to be pairing it up with a Shimano 110H. I want to Cast bullet spoons/poppers from the surf and from a boat. I'm prepairing for a trip to Kilwa at the end of October, and want to land a beeeeg GT. But I'm not sure what a good balance is. 1. Cast a long distance and 2. Land a dream GT. Please help!
craig54
Personally I would go for Sufix Performance braid .34mm ( 50lb ) . You would get +/-200 to 250 m on the reel . The thin line diameter will increase your casting distance and its super strong to fight the big Kingies . Maar jy gaan k@k en betaal .
Mango
Trevelly from a braid view in the 50 pound range should be fine .
YOu can not go wrong with a 110H briliant rod.
Is the saltiga surf 6000 not a grinder if that is the case then a 100H is the rod you want have a look i think Psy is selling 1
Trevelly
It is a 110H, if I remember correctly it was specifically modified by Solly's with a longer butt so that you can fit a grinder.
neilg
Trevelly
much more to it than just extending the buttsection.
"Spines" run on different sides on rods for multipliers and coffeegrinders
Mango
Also the 110H has 12 Eyes I do not know how that will affect your casting .You aslo said it was rebuilt was the eyes changed to spinning .
interesting fact :There was a guy that wanted to build a fly rod to catch yellow and longfin tuna with he used the 110H blank
Trevelly
Just checked, it's got 11 eyes. He must have changed them aswell. I used it for the first time last time I was at Cape Vidal (last year September). Another angler came over after the first cast. Can't remember his name, good with faces not names. Any case, he felt the rod and complimented it. Even asked where I got it from, cause he won't mind getting one.
Trevelly
neilg wrote:
50lb Powerpro
I've checked, seems 50lb at least. But the make, remains the question.
Neilg, you're saying Powerpro. Reefman, in his report on Kilwa used Whiplash, and it stood the the test of time. Craig54 is saying Suffix Performance. Thing is, if I hook a dream GT, I don't want to loose it. I'm willing to spend the money if need be.
neilg
Aqua dude, have you used whiplash for jigging and spinning ? Whiplash was made to be used as backing,.
Powerpro is thicker than Whiplash, so will be able to take more punishment.
Another option will be YGK.
Would personally stick to Powerpro or YGK.
Not saying the others aren't good, that's just my choice.
jaccil
I agree with Neil: PowerPro is the way to go.  If you have more money to spend, then you can consider some of the Japanese braids like YGK or Varivas.
If you're plugging/popping over flats or from the boat, Whiplash should be fine.  If there's any coral, rocks or other structure then abrasion comes into play and you'd be better off with PowerPro.  Loosing a big fish because your Whiplash got shredded on a rock is not a nice feeling - though it can happen with other lines too, just not as easily.
If you have a spare spool, it may be a good idea to put PowerPro on one and Whiplash on the other.  You should take a backup reel on fishing trips anyway, even if you have a spare spool for your main reel.
aquadementia
yes, been using the same line for about 2 years, jigging, plugging in the surf, fishing bait in the surf, in the rocks etc. It still looks new and is the only braid I've ever used that hasnt gotten wind knots.
yeah and mackerel where made to eat plankton but they make pretty good baits too :)
Trevelly
Ordered Whiplash today, 50lb and 60lb. Will get it during the week. Don't worry 60lb is not for casting.
Case closed, and thaks to all.
