Salina vs Spheros
Shimaiwa
I bought myself a Daiwa Firewolf 8.6 rated to throw 1/2 to 1.5 ounces and as my profile says, Reel is needed. I will be using this rod to throw 1oz bucktails, spoons, lures. I will probably load the reel with 14lb fireline. Bear in mind I am going to by the reel over the net and I can get the Salina 40 for $69 and the Spheros 4000 for $72, any other suggestions are welcome as well. Please tell me what you think.
royboy
We used the Spheros 8000 at Baza in May, and Linda caught the biggest GT of the trip on it. Some hardcore jigging guys suggest the drag needs to be upgraded, but out of the box at 21lb, methinks not. For DS, definitely not.
Have never been a "spinning Reel" person, but after using it in Mozambique, I am becoming a convert.
dugongboy
DD -  I have the Salina 55 loaded with 30lb braid - very good reel  - so far I have caught a 3kg YFT and 3 kawa kawas in the 3-6kg range all on 2oz. bucktails and the reel performed very well (not huge fish I know)
Why are you buying on the net ? Go to Akals and ask for a discount - I paid R505 for the Salina 55 last year.
Shimaiwa
Thanks Royboy and Dugongboy for your input.
I tell you it is scary how the price of equipment have shot up in the last few months. I am buying some braid for backing and also some more fireline. I am getting these at almost half of what we have to pay here.
G
Guest
Guest
DD,
I also have the Salina 55, haven't really put it through he paces but so far seems okay.  Only one thing scares me though, the line roller on the bail arm seems a bit dodgy - had my braid slip under the line roller and break off once, so now I don't use braid on that reel anymore.  BTW, I think a Salina would be way too heavy for the diawa firewolf stick - my impression is that the Salina was more for vertical jigging as opposed to dropshot which is what I assume you are wanting to do with your firewolf.  If so, I would rather go for a lighter reel like an exceller 2500 or 3000 or even the Shimano Slade - the slade is a good value for money reel for dropshotting.  The Salina would be way overkill.
Gilly
dugongboy
Gilly
What size braid ? I have 30lb Kingfisher Casting and haven't had any such problems.......yet... have caught a few decent fish(a kawa kawa of 6kgs is quite a good test) and the reel has been solid - great drag.
I tend to agree that it probably a bit big for the Firewolf but then maby look at the smaller Salinas like the SA40 ??
My 55 is paired with a 8' Kingfisher Custom spinstick and it is very well balanced - I can flick a 2oz bucktail about 40m with ease and a 2oz spoon about 45 - 50m
G
Guest
Guest
The braid was 40lb if I remeber correctly - Okuma braid!!! (could be part of the problem!).  What happened was I was vertical jigging on a fairly shallow reef and got stuck into a nice fish, but then the braid snapped right on the line roller on the bail arm so could have only been one of three problems: 1) Crap braid, 2) a burr on the line roller (newish reel), or 3) the line got nicked under the line roller.  When I inspected it I saw that there was a very small gap between the line roller bearing and its casing, small enough for fine braid to slip under but not small enough for mono.  But in all fairness can't say with 100% certainty thats what happened.  The Okuma braid is pretty crap too and I have now discarded it - wouldn't even use it as backing to be honest - you can just see the poor quality in the way the fibres are wrapped together - they show their individual strands very easily when rubbed between your fingers.
Otherwise the Salina appears to be a fine reel, and as you say quite a nice drag too, and at a fraction of the price of other brands in the same target market.  I have just resolved to using it with mono, but perhaps if I put a better quality braid on it will equally as good as the rest.
Gilly
Ziyz
I use 12b kingfisher casting braid on my salina 40. I've also had the problem of my braid slipping into the space between the bail arm and the line roller. Luckily its never happened while playing a fish.
Shimaiwa
Got the Salina about 2 days ago and all I can say is what a good choice, smooth drag, strong body. Definately give this one a look before anything else. Will give it a proper test when I go to Moz next week.
dugongboy
DD, good choice there mate, what size did you get and what braid did you load ?
I was in NZ recently and went to a few shops - the Salinas are highly rated in NZ and Australia - the one shop owner uses the 65 and 80 for deep jigging for yellowtail and has landed a few decent fish.
Shimaiwa
Thanks man, I got the 40 and loaded it with 10lb Fireline, this was after a long dicussion with the owner. It really blew my mind with its quality. This is my last post for about a week, I'm off to Guinjata Bay
jaccil
I would not suggest using thin braid on any Okuma spinning reel, especially not for surface plugs (poppers or walk the dog).  The problem with braid getting stuck in the line roller appears to be common to many models of Okuma reels.  It is even a problem on the top-end VSystem model.  I was using Wiplash Pro 20lb (0.06mm) but have to use a thick braid or mono on this reel.
It is a real nightmare when using poppers or any lure with a jerking action.  When the line is held tight for proper line lay (to prevent wind knots), the angle of line to the reel seems to make the problem worse with the line to get stuck almost every turn.  It doesn't cause too much of a problem if you're just spinning without the need to keep the line between your fingers, though it can still happen during initial turns.  I definitely won't be buying another Okuma for a while...  I like using the thin braid, and surface lures.
I'm also looking for a new rod/reel combo and trying to decide between a Spheros and an Exceler, I am leaning towards the Spheros.  On the rod side of things I am looking for a 7ft fast-action rod to cast 10-30g lures, but I'll have to shop for one once I get back in SA.  I'm looking for a really fast action rod to work surface plugs.  Any ideas?
neilg
What, a problem with a Okuma ... neva, they are even better than some higher in the range shimanos and daiwas ...
If you looking for a 7ft rod then I would suggest in reels something like the Exceller Plus 3000, small, strong and a really great reel !
I think (might be wrong) that the smallest Spheros is a 4000, which might become a tad big for a 7ft rod. But that said, the Spheros is a GREAT reel !
jaccil
The Spheros does have a 3000 version, but at 12.5oz it may just be a 4000 (12.7oz) with a smaller spool.  The Exceler 3000 only weighs 10.7oz.  Hmmm...  Thanks neilg, you changed my mind.
My real problem is finding a medium-light (1/8 - 1/2oz) 7ft rod with an extra fast action.  Shimano has a lot of options, with the best suited one looking to be the Teramar SE Inshore Spinning Rod TMSX70M rated 6-15lb casting 1/4 - 5/8oz lure.  I'm not sure whether these are available in SA or have to be ordered from the States (will need to make some calls if no-one here can tell me).  There are also quite a few Loomis rods in this criteria but all seem to have pistol grips and are rather pricey.
Any idea where I can find info on Elbe spinning rods?  The Internet doesn't seem to know much about them!
neilg
Boet, your guess is as good as mine.
Based on what you're looking for the one that I have is fine (Elbe rod), but I even throw 1oz with it. I have 2, a 1pc and a 2pc, this info is for the 1pc
Elbe Interceptor - braid guides (the stainless one) Model - SP7M
Has a fairly light (and thin) point, fairly stiff as graphite should be and very fast action. I have used it to cast very very light lures.
Unfortunately these rods don't have a rating on them. I paid about R 250 each.
I'M NOT SAYING THEY ARE THE BEST RODS IN THE WORLD, but I really cannot complain about mine, they have been used and abused and are still going strong (just like the Exceller Plus 3000)
Shimaiwa
With my Salina I cast about 100 times and the line caught in the roller once but I suppose with a fish pulling the line (Yes I didn't catch anything) it could be a problem. Will just have to cross fingers and toes :)
Just a rod suggestion http://www.fishingtackle.co.za/Daiwa-Firewolf/Daiwa-Firewolf-Spinning-Rod-FW-702MLFS.html I haven't used it, don't know how good it is but it suits your requirements
neilg
Dropshot dude,
what worries me with this "With my Salina I cast about 100 times and the line caught in the roller once"
one a normal day of spinning I can easily do between 200 and 300 casts, now that could mean 2-3 lures gone, and line possibly damaged.
taking into account the price of lures, it could cost me between R200 and R300 on lures.
3 fishing trips could then cost between R600 and R900 on lures, thats more than a good reel filled with casting braid.
What diameter braid are you using ? Maybe try going a little bit thicker to combat the problem, you will suffer a little on distance, but lose alot less lures.
