Rust de winter
van_straaten
going to rust de winter  in des (with a boat  )
Are there still kurper left in the dam ? and where are they ?
Also can you anker on the othe side of the dam across the dam from the camping area? is this allowed? as i want to have a braai mis day when the fishies dont want to bite
Otto
Hi Mot,
You can find the Kurpers towards the river inlet side of the dam as well as against the reeds. Take note there are some Crocs in the bay areas. Don't even try and get off your boat on the other side, its private property and I've heard the owner will prosecute you for trespassing.
van_straaten
thank you otto ... i have seen the crocks but more worried about those hippos --- the river that is to the right of the camping area right ?
Otto
From the launch site you go to the right and where the dam opens up you must keep left and follow the left side bank all the way up. Just passed the small island there are a couple of houses and thats the furthest you can go. The area where the houses are have nice little nooks and slipways that you can target. Another nice area is where the dam opens up toward the furthest part on the right next to the reeds. When you have reached a spot you like, make an effort to see if there are weeds below the surface area where you are casting to. If you are going to use a float start at 1 meter and work downwards till you find the Kurpers. Load the hook with 4 or 5 worms at a time, remember Blue Kurpers are very sneaky and the bite lets you think its just a small little fish, wait for the float to move sideways and down into the water before you strike.
