ROVEX SPECIALIST ADVICE.
Vypr74
Hi. I own 2 azores and love them to bits. Then I decided to buy a Rovex Big Boss 3. I took it home from the guy I purchased it from who stated it was serviced properly. The outer condition is immaculate with minor scuff marks. However upon leaving it on my desk overnight.. i arrived to find the reel abit geary. Very mild geary feel to it as you reel in. Any advice as to what I must do next. I am technically minded and work with micro electronics so I am able to assemble and re assemble anything easily so I opened my reel with care to do a routine check and found it was lubricated well and that there is no gear grind in the lube... and neither sheer marks on the gears themself. I did notice 2 shim washers were on the left hand side but on the right were the handle turns into, there were none.... any advice guys
Emperor
Administrator
Hi Vypr74,
I've attached the schematics for the Big Boss 3, hope it helps. :welcomesea:
::tight:
  • Big Boss 3 8000.pdf
