I bought a Rovex baitrunner approx six months ago, not sure of the model (it's lying in a box somewhere in the garage). I used it twice and was not impressed with the casting ability. Using 7lb line I was just lucky to get the line into the water now and again.  The line keeps on snagging in the front edge of the spool when you cast. The front of the spool in my opinion seems to too flat (minimal taper on the edge) and the thin line cant run freely out of the spool.  Yes, I suppose you could overfill the spool to make sure it doesnt snag when the line runs during the cast but that in itself is not always a good idea as an overfull spool has its own problems.
It will probably work well if you use thicker line with more "spring" in it as it will go over the front edge of the spool easier.
Other than that it is well made and has a good firm feel to it when reeling in.
