I always launch my inflatable from the natuurbewaring side its a bit cheaper than N/tvl gronde and the gates close much later, they dont check for skippers. When you get in turn right when you get to the water and follow the road all the way until you get to the circle, park and launch there, I have been out hundreds of times and have never had a problem with my car. Work the kranse Skuimkop mentioned, the trick is to put your baits/lures right up against the side under the trees, I often cast onto the bank and then pull into the water, the cats normally hold up against that bank. If it is quiet there then move across to the other side of the damn (opposite N/tvl gronde) where the hyacinth cable meets the side, it is alot shallower there so if you dont find them in the deep water then thats the next place to look. Normally you will immediately see them turning all over the place, if you see this then you are in for a good time. Baby bass coloured rattle traps work well if you are into lures and platties are great if you like to bait fish. I often rig a plattie onto a circle on my bass rod and work it around as a lure with great success.
