Rods and temp
Mango
How does low temps affect the castability of the rods that we use?
I know with the new hockey sticks most are composite mixture that are a pain to use when cold until warmed up. There is a shock absorber/gel system built in to lessen the feedback.
 Now to rods:
With them all being made out off composite is there times that you get more or less feedback from the rod when casting.
Does the wood built in to the butt section act as a type off shock absorber.
Hello Mango,
Low temperatures would not normally have an effect on the performance of a rod, although when it comes to ice fishing the short rods which are used are made of stiffened rubber or a lower grade of graphite to cope with the cold.
Remember though, that when they manufacture graphite composite products such as rod blanks, that the blank starts out as graphite sheets that are rolled onto a mandrill and baked at +- 1800C degrees to activate the carbon and get it to stick together.
So, please remember to keep your rods away from high heat sources as this may cause the carbon to reactivate, and no longer being on a mandrill, will cause your rod to be permanently bent.
Mmm, makes you think of some of the guys who store their rods against the roof!
Mango, the wood butt section does not act as a shock absorber, as your rod is not made to absorb shock, I feel really sorry for your rod if you use it in a way that it needs to absorb any kind of shock. This will cause your rod to break.
Cheers Van
Very few rods if any have wood in the assembly. The only wood really used in a rod is the wooden butting to prottect the base of the rod from bumps and scratches against rocks
I have fished in temps up to -8 degrees without adverse effects in casting or catching but generally in Africa you won't ever find constant temps affecting rods (word that can happen is wet line freezing to guides and breaking when a fish runs)
@Van some rods are cured at temps as low as 400-480deg in vacuum so taking a heat gun to them wil make them just fold over
