rods and sun
roland
guys, ive moved to a new place, bit smaller than the previous . my dilema, cant find a place to put my rod (purglas 400/3) dont fit anywhere inside my place. the only place i can find for it to lay down straight is outside on the patio , and theres sun all day long, will this damage my rod? maybe i should have it customised to a 3 piece lol :fbash
Eina.  The varnish on the rod itself will harden and get pit marks, the rod can also warp as being a tube and heating on one side all the time will cause warping.
If you can then rather store it in a bag and better still in a bag in a PVC pipe.
As a bit of advice I would recommend that you buy a 4.5m length of 75 or 100mm PVC pipe with end caps.  Store the rod in the pipe out of direct sunlight and you can fit padlocks to the end caps and secure the pipe to prevent theft.
roland
As a bit of advice I would recommend that you buy a4.5m length of 75 or 100mm PVC pipe with end caps.  Store the rod in the pipe out of direct sunlight and you can fit padlocks to the end caps and secure the pipe to prevent theft.
still too long for the place i stay in. isnt there maybe an oil or something i can put on it for protection?
kitefisher
:fbashRoland ,vra daai befaamde stok-bouer in Jeffreys om die 400/3 vir jou te verander na n 350/3 toe, dan sit jy hom sommer onder jou bed,lol
:wfish
roland
:wfish
Gaan dit niks doen aan die stok se aksie? Wil darem nog nou en dan n haaitjie vang haha. Hmmm, of ja, light tackle en haai haha. Ek bel hom gou.
kitefisher
Roland ,just in case we're not on the same vibe here.In Purglass all their older 350 length rods originated from a 400 length blank which was shortened from the butt-section to either 350 (3,5 meters) or 325, or even the popular 375 length. I could be wrong but the 300 length may have been a different mandrell (not sure about that,if not the same process as above was followed at manufacturing.)
If you change the length to 350 and keep it one-piece like I suggested you may be able to store it indoors somewhere ,or else try under your roof as suggested,or find a friendly neighbour who also fishes and use his garage.::S
ps, As far as action goes it should feel a bit stiffer in your hand,and would probably be more manageable to cast as well.Pulling may also improve due to you pulling on a shorter lever.
Psy
I second that...a rod i broke has been made into a two piece, and now has a different action completely. Throws much further than before.
The same mandrel is used for the 300, 350 and 400/8 but the pre-preg wraps are made and wrapped for rhetorical required lengths. They don't cut back on the original blank.
I do however cut down on the butt section of the 2 and 3 piece rods so that when built up the sections are of equal length.
Making the 400/3 into a 350/3 will still keep much the same action and casting weight range but at what price.
I would still if possible find a place ie under a gutter etc to hang a pvc pipe to store the rod in.
This is why most europeans and now South Africans have gone multi-piece.
I would sell the 1 piece 400/3 and buy a 3 piece, problem solved
roland
it was a gift lol.
roland
thanks for all the help guys. in the future i will maybe consider shortening it too a 350, if my casting doesnt improve. but for now.....
problem solved, thanks SPIN who s helping me out with a rod cover
roland
aaaaaaaaaahahhahhhhhhh my poor rod, its raining and i cant take it anywhere. the rod cloth is already soaking wet :( :(
Firoze
Hi Roland. I have both the 350 and 400/4. The 400 casts way better. I wont advise you cutting the blank.
