Rod Revamp
bapsfontein
I got a few old rods that I want to add a little something to make them looking better like a nice flash and so on..
1. What spray do they use to creat the flash.
2. What Epoxy must you use and where do you get it....the epoxy I know is the ones you use for model aircraft Bob Smith.
Jess
You can use any lacquer spray but for durability we use 2k Automotive and coat it with 2k Clear Coat or Glatex to protect it
For the guides and sealing binds we use FlexCoat as it gets hard and protects the binds but remains flexible and doesn't crack when working with the rod and it doesn't yellow either which is the biggest problem with 99% of other epoxies.
www.mudhole.com
If you want then bring the rods with for the flash etc and I'll put it on with the airbrush
