Rod recommendations?
Bijen
Hi guys
I have recently acquired a stradic 8000 fi reel and the next step is to source a rod for it. What "off the shelf" recommendations would you guys suggest? Was looking at some 10ft options but I think this maybe a tad small for the reel? Planning to use the rod for spoons, plugs and maybe an occasional small bait for gullys. Somewhere in the range of 1oz to 3oz. Is this too light for the reel?
My budget is between 1000 and 1500. Can push for a bit more if its worth the investment.
Any help would be appreciated chaps.
Thanks,
Bijen
G
Guest
Guest
Drop Enigma a line. He has a few options that he can put together or you. I have been toying with the idea of a Blue Marlin 3 piece. The first 2 sections to be HMG ie stiff and the tip section t24 which is a bit softer and more forgiving. To my mind this would be the ultimate machine combining great casting with good pulling power.
Bijen
Thanks for the feedback Haakies, CEO and seeker. I will have a look at the exage first before giving Neil a shout. How much do the exages go for, what are they rated in casting weight and are they 3 piece?
Will it be worthwhile puting a bionic finger on?
Thanks gentlemen
Seeker1
Exage 10ft is 2 piece, sell's for around a R1000.
I would say it's the best off the shelf rod you can get at that price.
BTTB
I have yet to catch a Yellowtail with my 10ft Exage for the simple reason I use the 110H with a multiplier and would have to re-adapt my style of fishing, but I have seen guys pull big Yellowtail with this rod using the exact same grinder and lift them.
I did however use my 10ft Exage to catch Cob at Henties earlier this year and I must say this rod with braid you feel everything even the sinker rolling on the bottom, the rod literally comes alive from tip to butt.
BluFlu
Ditto Exage - can throw 3 ounces comfortably where most of the other offerings begin to creak a little (Berkley Air etc).
Re the Binoic finger - no - I put one on my spinning combo initially but it is a real hassle when you are casting alot. Would recommend you just tape your finger if you feeltheneed or get a pair of MTB ful gloves.
Remember the trick when casting a grinder with braid is to make sure your drag does not pull when you are casting. Static braid on your finger is manageable- sliding braid is well a little sharp.
If you're not casting anything over 5oz then don't bother with a Bionic finger as it's more in the way than any good, especially with spinning.
Rather invest in a roll of Elastoplast Extreme or a 2l coke bottle neck and flap.......Guess that one has you puzzled.
Just built a Thunderbolt 10' for a 8000FI and it's at Tofu at the moment pulling some GT's on the 50lbs and a lot of all manner of fish on the 20lbs R1250 for the custom, can be fished from 20lbs to 80lbs braid applications and will cast 2-6oz. I use a really crappy design Awa-Shima rod and strip it down to the blank which is light and superstrong (2 piece)
10' Exage if still available is your best buy off the shelf, awesome rod.
foot soldier
10 ft shimano tiralejo 8-15kg,rated 40 to 80 gram but will throw heavier and lighter,built with fuji sic guides,,the best 10 ft allround rod ive used,works well for large plastics,hardbodies,surface poppers and metals,i consitantly get 100+ meters with 65 to 85 gram metals and 30pound powerpro,,has a sweet action when hooked up on big fish and the balls to redline 40pound braid,,i have a saltist 4500 on this rod and another with a saltist 30h
Tiralejo and the Thunderbolt blanks are pretty similar in action but the Thunderbolt is a touch heavier and here it's a bit out of the price class Bijen is looking at.
Got to love the heavy Tiralejo with the sliding reel seat, monster rod that one
foot soldier
im not farmiliar with your currency,,$1500 would get me 5 tiralejos here :D cheaper options in my neck of the woods would be a pacific compisote 4120g,5120g(the g stands for graphite,,4120 or 5120 wilson live fibre,you can get these blanks cheap and build your own with cheaper fittings to keep the price down,,these were the standard beach/rock lure rod untill the newer rods started coming out,but many still use these as they are descent price and can take a knock on the rocks,,and yes the 13ft heavy tiralejo is a ballbuster,good slidebait rod
So 1 x Tiralejo = Aus$300 = ZAR 2100 and he's looking at R1000 budget (ie Aus $120) Therefor recommending the Exage (a range built solely for RSA) or the Thunderbolt.
The 10' Exage is based on the front 2 sections on one of the Euro Style 3 piece 15' rods. Is an awesome rod for the application he has in mind
Now that I think of it the Sensation shad Pro, spinning will be a sub R1000 option that will doe 2-4oz and is really good value for money
foot soldier
pacific composite 4120 go for around $95 off the shelf,these are what i had before i got tiralejos,,best value 10 ft rod around here in my opinion,,you could build one with better quality eyes for $180 and have a top rod,there are many off the shelf 10ft rods here for around 180,snyderglas and kilwell live fibre are good options
None of the others you mentioned available in RSA so he'll have to look to sensation, Shimano Exage and I'm sure there'll be a Daiwa somewhere in that price class
Yip Aus$ nd USD about even so his budge is between $90-125
Bijen
Thanks for the heads up guys;) The feedback has given me a good foundation to make a decision. Its interesting to see the variety in tackle in different countries!
I am pretty keen on the thunderbolt Craig. Will give you a call next week to discuss. Sounds like a great bang for my buck.
Cheers,
Bijen
