Currently a Blue Marlin T53 4-6oz
I would buy it with 2 tips:
Standard tip. the fact is the rod is designed for a purpose and the heavy tip is matched for that purpose. the first part of a multi piece to break is always the light tip.
I do a lot of refurbs of multi tip rods and in 80% of the cases i redo only the heavy tip, in 19% I do the heavy and medium and in 1% i do the light.
IMHO the multi tip rod is just a marketing Gimmick
The 2nd tip I would buy is the Short heavy tip which is basically the Shark Extreme medium tip - that's the one you would slide a bait for a big Kingy with.
I have one of these rods and in this exact configuration. With the standard tip you can cast 5oz with larger bait, 6oz with standard baits or 8oz for slide or with a pencil bait.
Add the short heavy tip and casting an 8oz with bait or 10oz slide is possible
Combination custom built with Fuji MNSG guides and Trigger winch will set you back around R3600-3800
Purglas 350/4 would as standard so basically all you are looking at and with same build currently cost R2400 and with new HMG builds cost around R3300.
For eds fishing I prefer a mix of HMG and Intermediate carbon as it gives the best of both worlds.
Lighter, just as strong and the tip has a bit more whip in it making it more sensitive and prevents hook pulls and the cushioning helps to protect lighter lines when bigger fish lunge for freedom, especially close to the bricks.
In short my dream rod would be an HMG base, 75%HMG mid section and a 25%HMG tip. Light, powerful and capable of casting 5oz+Bait to 10oz slide weight.
The USA rod makers have shown that using the right engineering you can make a light enough rod that can deliver just as much power and not being HMG is less brittle and less prone to snapping under extreme pressure.
Is this possible. We're working on just such a rod.
We have just finished an ultra thin 11' blank that can cast from a 1oz to 6oz lure using mechanics just as indicated here (without HMG) and it can be used with tackle up to 80lbs braid, it's big brother will do 4-8oz and take up to 130lbs braid
