How do you take off the pesky rod eye on the tip of a rod?! I need to fit a new one and I'm worried I might damage the sensitive tip while trying to loosen the broken rod eye. Any tips (excuse the pun...) to get it loose enough for safe removal?
Have a look at the tip and see if there are any wrappings around the metal sheath of the tip eye.If there are cut them off.You will need some one else to tell you how to put them back on but IMO they are 90% cosmetic.Heat the metal of the eye with a lighter for 10 sec.Then grab the eye with a plier and pull off.
Hello Hooked,
I did scrape off the varnish and threading. The metal casing of the tip is now exposed but still firmly fixed to the rod tip. I have tried to heat up the metal but with no luck, still stuck...
Try using a heat gun if u can get hold of one but DONT overheat the tip , heat it gradually, will soften the glue/varnish , and pull off with plier /visegrip... DONT twist as u pull it could shatter or splinter the rod tip.
Thanks guys.
I decided to give it another go with the lighter. This time I heated the metal sleeve of the eye from the tip gradually working my way to just before the graphite starts and... wollllla it came off with little bit of tugging.
Only thing is I see I have made a very thin cut into the graphit (?) when I was scraping off the varnish and threat. Reckon I should cut that piece of? I would say it is about 2cm from the tip.. and barely noticeable.
Aarghhhhh!
