Rod Conversion Opinions
aquadementia
Hi guys
I have a 10ft Blue Marlin Carp Rod, called the Carp 10
It has a really nice action and I was thinking of getting it converted into a telescopic rod, with the line going through the inside of the blank...(apparently possible with some mods).. Basically a baby barbel calling rod, but for dipping carp
I guess it doesnt have to be telescopic, but it may be more convenient when fishing
Any ideas or recommendations?
The Owner
The rod will be shorter if converted. The shortest dipping rod I will recommend is 14 feet. Also remember that the friction inside the rod tube might be severe especially on thinner diameter fishing line. I will recommend an inline telescopic only where you fish for carp in heavy structure, eg between reeds.
Is do-able
Have the inter-line guides and you can buy from Blue marlin
It is the G2 10' 1-2oz T24 blank used for that rod
Trim down the re-inforcement wraps on the base of the tip to allow the tip to get a lot further up, do it bit by bit
The outer of the base doesn't need re-inforcing
Enjoy the project
aquadementia
ah thats no good then... I got sponsored a customised calling rod about a 12footer, but it feels a bit heavy far carp...
what would you do with this rod? I've got it so might as well use it :)
perhaps I can get the but extended another 4ft somehow
aquadementia
Enigma wrote:
Is do-able
Enjoy the project
how would I thin out the base? my first thought is a lot of sandpaper and elbow grease...
Rod lathe and sandpaper easier
You can take the thicker stuff off with a blade and try prevent it cutting in to deep
YOu can shorten it by 2' and use it as a casting rod for catfish with Lume Lures or a Swimbait rod for Lunker bass
As is is a good river or short range Carp and Barbel rod
aquadementia
I've already got my vengeance 8ft for the pumpkinseeds, love that rod
BUT this bm is such a lekker blank, i wanna use it for something... would like it totally rebuilt from tip to butt...
will have to think about it...
i dont fish from the bank at all, and I just got a 15ft semi rigid so was thinking a boat rod
thanks for the advice!
