Rod advice neede
van_straaten
After breaking my rod and reel this holliday i need advice
I like my coffee grinder but it does not seem that there is a rod that can handle the fishing i do
I want to buy a new rod 12 foot + but i want to use my grinders
staffie ? or a loomis ?
I dont want to spend a couple of grand on a decent rod and not be able to use my grinders
I notice the rods eyes are diffrent and the first eye is farther from the bud of the rod
and the handle is shorter  can i put a spinning reel on there ?
thanx
surfaMIKE
You can definitely cast a grinder with a short butt section, you just hold the line with the bottom hand and hold up on the rod with the other hand (same position as with a multiplier). There no reel rod limit for a grinder, and the smaller eyes, dont worry about them too much. I can outcast myself when I put a grinder on my multiplier rod that has small eyes, compared to when I use my multiplier on the same rod
Loomis & franklin 12ft would be fine. They go for about R800 - R1000 more or less. I have one and love it, but use it with a multiplier, and I will admit that the eyes are a tad small for a grinder, so just replace the bottom eye with a larger one, if you really want to.
Staffie? I dont know what that is, besides a breed of dog (and what some people look like :fbash)
Hope this helps
camo shorts
When selecting the rod, rather take your grinder along that you plan to use, check if it fits in your hand and is balanced. Most rods are available in spinning configurations, and that larger first eye, really adds to your casting distance imho.
thebigman
Most rods for the fixed spool reels have fewer eyes as well. With the line being under the blank the eyes dont have to keep it up off the rod.
sharky01
sorry for hijack, I bought a Penn Sargus SG6000 today and would like to match this with a spinning rod .. problem is the budget ... looking to spend around R600 ...
Marthin
Blue Marlin makes a 14ft surf rod spesifically for casting with grinders with an extended butt section.
Yes you can cast a grinder with a short butt, although it's not nearly as effective as an extended butt section.
Arno Nel
The Exage has nice big guides on so it should be graet for a grinder even if it has a short but.
The other option is a Sentation Shad Pro Spin 12', I have one matced up with a Daiwa Exeller Oceano 4500 loaded with +/- 450m of 9kg King Fisher Casting braid.
This combo works great for scratching and for Shad.
The rod is rated 2-4oz and it is a 2 piece
van_straaten
thanx for all the advice im looking for somthing that can cast an 7 ounce .... is the bleu marlin a 3 piece ? where in pta area can i buy these rods ? exage also
Fishing Pro Shop at the corner of Lynwood and hans Strydom, it's in a huge plot and is to the back of the tile sales are
Angling Africa below Lighting Warehouse in Centurion, just South of the Mall
Sollys Anglers corner across from the Waterglen center (SE of Menlyn mall
Solomons Gifts in Pretoria North.
Your best bet for the rod you're looking for is the Fishing Pro Shop and Charles Stewart will give you the advice you need as well as a demo if how to cast a Grinder on a short but rod.
If they can't help you with a demo pop in at our warehouse or our neighboring (not our shop)tackle shop Tacklemania (corner of Paul Kruger and Booysens)and we'll take you down to the Munt dam for a few throws to show you how. Tacklemania only has a few R&S rods and you'll find Exage, Poseidon and BM rods on the rack.
Moyeni
Mot,
What ever you do,don't buy a Poseidon Staffie it is not made for grinders...
A friend of mine bought a Kingfisher "Trident" specifically made for grinders and it is strong.
Give them a call on 031 - 368 3903
