Rocket fuel
nevilled
Did you guys check out Papenfuss new dvd. He suggest that if you add a bit  rocket fuel reel oil you will gain 30 m on your casting distances. Did any of you guys test this method, if so any tips or disadvantages. I would also suggest anyone trying out this method to do so at least a day before a fishing trip as the chemical scent could effect your bait.
nevilled
It is a casting dvd, basically explaining the different methods used to cast for drop shot, long distance casting etc. The dvd teaches you the pendulum style casts with a few extra tips on how to reach a desired spot in the ocean. Value for money...not too certain as i am still learning to cast and only reaching 110m at the present moment,maybe the rocket fuel which i have purchased from Basil Manning for R74-00 for 30ml will help.
nevilled
TG,s Rocket fuel, hi speed reel oil, yellow label.
*Perfect viscosity
*Doesnt evaporate
*Doesnt Emulsify
*Doesnt Congeal
*Wont wash off
*Wide temp range
*Stays clear and clean
*non-corrosive----not for internal use--some big words so pull out those dictionaries.
Walt
Nev : Any idea who the main suppliers are as I'd like to see who would supply it in Cape Town?Is there perhaps a company name or contact nr on the container?Thanx!
DWB
Hallo OOM WALT
Wanna make that saltist cast a mile?
I know whaler will soon have his stock, customs wasn't too fond of sendind ROCKET FUEL over the border.......
Otherwise Basil Manning sells it over the web.
Keep Well
