replace tip eye
sven
hey there all,
does anybody know where i can get the eye on my  stand up rod replaced in jo'burg. i know the year is nearly over and the okes are going to close but only saw it yesterday.:headb please going to st.lucia 5 jan need that rod there.
tx appreciate the replies.
carcharias
Hi Sven. If you are really stuck I will help you to do the fitting. You will need a new tip , some binding and a sealant to cover the binding. Clear nail varnish can be used in emergencies. I have all the other tools needed.I am in midrand . If that is not too far from your location I will gladly assist you
carcharias
No unfortunately not . As I said I can help with a emergency repair that will last at least until he gets back from st lucia. I have repaired many rods this way and they always last. I repaired my purglass 400/4 in the same fashion and have still never needed to redo the fitting of the tip.the repair was done more than a year ago(4 long trips). The other option is to speak to the guys at raggie tackle in st lucia they will do a similar repair. The owner and his wife are really helpful and will also assist with deepsea trips as well as where the best spots are
sven
tx reefman,much appreciated. looks like i am going to be to hectic to actually get it to bedfordview, end of year run around trying to get everything finished before i close.
might just go with carcharias idea of maybe getting it done down there.
tx again and tx carcharias.
Hooked
As far as I know your tip eye does not need bindings.Normally it is glued on as it has a socket.
When I have done this before I have used heat glue which you can buy from most tackle stores.
Just be sure to take your tip eye into the shop with you to match the socket properly.
carcharias
Most dont need binding . I always try to get the ones with a small "tail " that need binding. I may be completely wrong but , I think that they are stronger. Personal piece of mind I suppose.
