Removing braid
Bux
I wanto take some of my reels back home next week as I dont use them (and going to replace them with some new one - but dont tell wive!) but some of them has got still perfect braid on which I want to remove. Knowing the twisting capabilities of braid...how do I go about removing it so that I can put it on any other new reel whithout all the hassles of ending up with line twists and problems? Oh its all coffee grinders by the way!
Bux
Thanks, I figured something out that uses the same principal. just thought there is a right way of doing it that I dont know about.
Fin-S
Take an old empty spool. Put a penny washer on a long bolt, then put the spool on the bolt, then another penny washer and then a nut. Tighten up and you have the spool locked onto the bolt. Insert the bolt into an electric drill (pref. with variable speed), tie on braid and apply power. The spool will turn and line will come off of the reel onto the spool. It will twist. However, as you are going to reuse it, when you respool, simply turn the spool around and as you rewind, you will untwist at the same time.
Bux
If i thought about the drill at the time i wouldve saved alotta precious calories! Next time though.
