take off circlip washer should be below it. pull shaft free then. Press out bush carefully then push bush onto shaft and checkout the sideways play. Replace if wornokay, I got that part now, but I dont see any washers near the circlip? Is it supossed to be between the circlip and the graphite? Maybe thats the reason for it being loose? Is it a small washer?
Bingo, typical of the 20/40, try and get you a new main shaft, just try and get one with the screw at the bottom of the shaft, your 20/40 has the old type shaft in. . not a major trust me,just replace the main shaft. . .shot!I just checkd the inside...main shaft is loose?? What now? Will it be possible to fix it within 5 days?
