Reel from Quantum...
flippy
looks nice n all, spares might be a pain if only from U.S.
BASS World, Pro Angling Equipment in Centurion are the agents for Quantum, I've seen a few Quantum IronSide reels in stock and they do the Cabo jigging and dropshot reels so they will either have these reels or be able to source them: (012) 665 4293
old salt
Hi the quantum and the finor is the same reel no difference one and the same just marketed under another name chat to Darius at smooth drag he carrys spares the reel is MUCH MUCH stronger the the torium and saltist i believe i stripped it and it also has a stainless main gear BIG line capacity without the reel becoming too big,  massive bearings solid spool shaft good size one way roller bearing too, prob the best shark reel i have seen thusfar from a design point i think it knocks the others hands down out of the box and priced much better too the yanks have always over compensated on design and this reel is no different i give it 9 out of 10 the toruim 6 and saltist 7.
surfaMIKE
Finnor has 5 bearings, quantum has 8 bearings right? My question now is: why do you need 8 bearings? In a multiplier? Even a spinning reel for that matter? My belief is more bearings, more trouble. I try to stay away from reels with more than 5 bearings. Even 5 is too much for me. I just dont see why all the manufacturers are cramming so many bearings in a reel... any suggestions as to why?
Whaler
Hi, the more bearings the better, as long as you maintain your reel it does not matter how many bearings there are, the fact is that all reels have the same amount of moving parts and if they dont have a bearing they will have a bush, in my book a bearing always beats a bush...
old salt
HI a bearing has better resistance to wear than a bush; a bearing spins better and works much better under load as well. A bearing looked after will outlast a bush any day; also under load a bearing will help in the rotational stresses that are involved all one needs to do is grease it its high load and low speed or oil with decent oil if its high speed and is will last very very long indeed. Once bushes develop play they create lots of wear in places you always dont want it and so gradually the reel starts to wear everywhere due to loose tolerances thats the main reason a bearing is better, most times its also reasier to replace when needed.
surfaMIKE
Thanx old salt
But the oldest and most used reel in this house is my dads crusty 35yr old jigmaster. It has bushes, and has caught more fish than all the reels in this house put together. My dad has never changed anything on the reel except the spool. Its still very smooth, so thats why I am doubting bearings last longer than bushes
old salt
hi at that time bushes were all that were used if oiled or greased in the penn case it wil last long yes but it wil not out perform a bearing or outcast it either, the older ABU reels were the same reel breaking technology when it came out then when bearings were used the bushes were discarded all together bushes are still used in certain reels to keep cost down for example but the bearing looked after is better indeed. When you have  abush and a shaft running together wear develops quicker than a bearing that runs in balls and the shaft rotating on the race on the inside.
Take the speedmaster for example see the post speedmaster upgrades the driveshaft bush was ALWAYS a headache with the bush wearing then the driveshaft iftself wearing and the whole set up had to be replace then shimano brought the kit stanless screw instead of the brass collar and bras bush same stoey wear wear and wear then i did some headscratching and now i fit a bearing in place of the bush all the problems are now solved.What also needs to be checked dont run brass on brass it wears too quick rather stainless on brass the stainless must be highly polishes as well to ensure limited friction.
surfaMIKE
Well I use a very thick and sticky oil called "tenacious oil" on the bushes and moving parts of my jigmaster. It is originally for bicycles, but because of its water resistance properties, I use it on my reels. It works great, and lasts long, and because the fish arent 150m away where I fish, I am not bothered about casting distance (I actually lose more tackle if I cast far because there is a reef further out). I still have the ability to cast about 100m but its not needed where I fish because If you throw far, you throw over the fish and end up catching nothing and losing alot of tackle
but thanx for the help hey
old salt
Hi always a pleasure the old tried and tested tackle is great yes and take sone down memory lane for sure, those reel were all very revolutionary for the time indeed. Many things became possible due to its design, carl Newell improved upon it and then sirs Daiwa Shimano and All the rest ABU included copied what was done here. Enjoy the trusty penn boss its good stuff.
old salt
Simen thankx for the reminder 3 attempts latter i has accepted i think let me know if it reflects updated your side as well.
