Reel failure: Saragosa 8000F
Echo7
Last Monday my crew was on with a big fish on a bottom trace, whilst fighting it he felt the gear slip and then the reel locked up. This carried on for about 10 mins till he lost the fish. We didn't use the reel for the rest of the trip.
On opening it up at home, this is what I found:
The tiny screws holding the main gear to the handle shaft had come loose, all of them!! (Pic 1)
This caused the gear to slip, in addition the loose screws ground away at the side plate causing a nasty burr with lots of metal scraped out (Pic2). The screw heads took quite a beating and some threads were damaged. I called around to Basil Manning and Lucky's in Manaba but they didn't have the parts in stock.
I cleaned out the screws and gear threads, loctited and replaced all the parts. It seems ok but I haven't tried it out yet.
Just a heads up to guys who have this reel, to maybe check it out and if possible loctite and torque them properly.
neilg
Did u buy the reel new ? Who serviced it ?
Those screws normally have threadlock on them. And that sideplate looks stuffed.
Abaddon
Stradic is the same on the inside, I still prefer the Stradic anyway
Davo
Hi Echo
I have the same reel and borrowed it to a friend that took it up to Mozambique, he was jigging and after landing and losing about 8 kingies the reel wouldn't reel. He bought me a new reel and gave me the original to have a look at, when I opened it, it was exactly like yours. I also had only used the reel a few times. I have had the parts replaced and I’m going to put locktite on those screws
