RC Bait Boat
thebrain
Hi all
I need some help. I have fabricated a bait boat (for fishing).
This weekend I mounted the engine inside the hull, and then used a carbon fibre rod inside a copper tube as propshaft. The propshaft broke during testing in the swimming pool :-( There was also a lot of vibrations.
Where can I purchase (or who can I contact) a propshaft, as well as a universal to accommodate small vibrations?
I would prefer to buy secondhand (as I will only use this on my fishing outings), but otherwise I'd pay for new ones as well.
I live in Birchleigh (Kempton Park) and work in Bedfordview, anywhere in between and surrounding area would be much appreciated.
Tried Hobby shop in K90 centre (Boksburg) and Hobby Centre (Kempton), no luck.
Please help!
RobertG123
There are not a lot of people with spares for baitboats that I have found. I got a Prop and shaft and universal from a place in Clairmont in Pretoria. contact number 0827721553. There are a couple more but don't have conact details.
Frikster
All the boats i owned had some sort of a plastic pipe that connected your shafts.It all depends on your thickness of the two shafts you want to connect.I used the Festo pneumatic pipes to connect mine,hope it makes sense and help you.Bottom line is that a plastic or hard rubber pipe will act as a good universal.
Frikster.
thebrain
Hi Guys, thank you for your replies. I visited Airborne Passion model Crafts & Hobbies, Village View Cntr, Bedfordview (011 455 2110).
There I explained my situation and was assisted in a friendly manner. I ended up purchasing:
  • A thicker brass rod (5 mm)
  • A thicker brass tube (tight fit with rod)[/*]
  • A universal joint (similar to http://www.hobby-lobby.com/ujoint.htm)
  • Two fittings to connect motor and rod to univeral[/*]
  • Boat prop[/*]
  • Some silicone grease[/*]
Works quite nice, except now the rod tends to slip outwards. Does not matter how tight I turn the little set screw (allen key) on the coupler on the motor side, it keeps disconnecting, and then the rod slips out.
How could I prevent this from happening?
im also working on a prototype( my bro-inlaws father is actually im just a fisherman lol), he build model aircrafts etc and lectures at a university and has access to carbon fibre so hopefully soon we will have a working unit to test in the big blue
Pats
tHE BOAT MUST BE FINISHED AND RUNNIGNG BY NOW BUT IF YOU DRILL A HOLE JUST 2mm INTO THE SHAFT 1mm BIGGER THAN THE SET SCREW IT SHOULDNT COME OUT.
pOST SOME PICS OF YOUR BOAT PLEASE
