Rare Bimini
noor
Last week i was fishing and came across a fisherman that had this long bimini twist around 500mm looks as if it was plated onto his leader..iv never seen this before,,can anyone explain how they do it?
Mango
Hi There
What they do is make a Normal Bimini with a verry large loop and long tag end.
The loop is split leaving you with 3 equal lenghts.
These are then platted and finnished off with a fig 8 knott
Found the guys in the PE clubs do it that way
Kathie
It's a Bimini with a long tag end so you get 3 tag ends. Which you then plat then you put an overhand knot to lock. After that you start pushing the plats closer then another over hand knot to lock the tight plats. Then you join leader using the F8 with 2 turns using a plier to tighten. Wet lines pull the together. I'm use this all the time. Super strong but don't make the bimini to tight as you need the stretch. My 2cents.
