Rapala Skitter Walk
Ben REINERS
Try GANIS in Witbank, 0136927199 or 0136926810 & speak to Hussain
Alternatively try Basil Manning Durban or Sollys Angling, Western Accessories or Alcocks tackle.
Ben REINERS
Ths best bet is to call them telephonically & ask.
Once newer lures or models come onto the market, the old ones are normally removed from the on-line ads.
Never trust On-line sales.
I have learnt & found if you look for older tackle to call & ask an assistant to actually go look.
You will find at one of these shops.
Hi Fly aholic.
Once again unfortunately the same story. I believe the xrap skitter walk is also out of production, discontinued for sometime and would be harder to find even than the other xrap walk. So to answer, No , not available at all. collectors item and for those that are lucky enough to own, a superb walking lure. But i can assure you, the skitter v you are not such a fan of is just as affective and easier to use.
Hope this helps.
