Fishy2
I can only find a 325/2 on the Purglass catalogue,however the first digits only signify the length so it is not that important,what is important is the /2.All other Purglass rods in /2 can cast up to 6 oz which means you can use it for scratching and even moderate-sized edibles like cob ./2 is a good allround rod and if you wanted to slide smaller baits for edibles specifically it would work as well,as in sliding for kobbies that is.Regarding the reel most suitable I would think a Daiwa slosh30 or Grandwave 30 would be great for scratching and edibles.Couple this with a line of perhaps .40 mm.
At a push you could go for the grandwave 40 on it,with perhaps a .45 mm line.
Start casting it with a 4oz lead and then work up to the 6 oz that the manufacturer recommends,you never know if the butt-section maybe took a knock before etc etc, so just take it easy with any second-hand in the beginning.Once you are confident of its capabilities,you can let rip.
I would personally use it with 5oz and medium sized baits or 6 oz and small baits like bay/baby-squid..
Tight lines
