Problems with knots
It's interesting BB, that the Uni (doubled) is OK when tieing braid to braid, or tieing braid to terminal tackle. The problem comes when tieing braid to nylon???? What are your thoughts here???
BigBass
Thanks for the link, Reefman!
Will study the article ...
Wonder, though, just how real life experience in actual fishing situations stacks up against machine testing knots or "lab" statistics ...
Variations in individual style when making the knots and connections could also play a role as would fishing styles (initial and other drag settings) and tackle used (S or E Glass, graphite or composite rods, taper of rods, jerky or smooth drags) and the quarry pursued (fast running and hard hitting fish such as tuna) ...
Also boils down to what one has confidence in from personal experience.
Feedback from other anglers as to their personal experiences may be enlightening too (on a one-to-one basis or "trawling" though the various fishing forums online), especially if this seems to reinforce/ confirm or even cast doubt on, your own personal experience ... The bottom line (excuse the pun) if you are losing (or have lost) fish through knot failure or unexplained line breakage, is that there is a problem that must be solved.
For about the last 7 years, I have fished braid (Berkley Whiplash - not yet the Pro version - with a mono leader) on all my fishing set-ups (Surf, Bass, general freshwater) and have not yet lost a fish due to knot failure or line breakage. I have been bitten off by toothy characters when not using wire, I have had hooks straightened out when using braid straight through (initially) with no mono leader, but no knot failure or line breakage. On occasion, when having to deliberately break off after getting stuck on the bottom, for example, its a real chore when you deliberately have to break the line. (The easist way to do this is by winding the braid around a smooth short section of wooden broomstick and walking or pulling back ...).
I have used the Uniknot with the line doubled when doing the knot ever since the early 1980's after seeing an artcle on the Uniknot System in a 1982 Field and Stream magazine ... Of late, I have also used the 3 loop Centauri knot. On occasion I have tried the Palomar in heavy mono (60 - 80lb test). All these knots have performed well, also the Uni - Centauri braid to mono join I descibed in my previous post ... Even the back to back Uni joining mono to mono or braid to mono, has worked well for me ... But then I have not yet beached a 100kg Raggie or Bronzie!
Let's hear some real-life experiences (losing big ones or the PB of a lifetime or just any fish) with the various knots out there - knot failure or breakages that can , most likely, be attributed to the knot. None such for me with the Uniknot even though the machine test stats do not seem to agree ...
By the way, I am not sponsored by the Uniknot Corporation (Joke!) :D
I also found a link to the PR Knot (which Nepptune seems to like so much!): http://www.jigsdirect.com/eMerchantPro/pc/fishing_knots.asp
Only disadvantage seems to be you need a special little tool/ bobbin to tie this knot.
Thanks again to Reefman and all the other Sealiners for this Forum and all the info and experiences you all share!:cool:
Nepptune
BB - What a great post.... this is awesome reading, and all feedback from a guy out there fishing and using the knots, which is awesome to hear and learn from.... The lab tests are great, and can be very useful, but nothing beats actual application and use of these knots/lines etc in real time situations! That is where its at!
I think one of the most important things, is to use a knot you feel comfortable tying, and that you have confidence in.... This advice was also given to me as a kid regarding what choice of fly one should make...." The one you think will catch fish" was the answer.... and its so true to a point... have faith, and you'll be a better angler for it...
BB - That link for the PR knot goes to the same page basically, the Jigsdirect page is Chris Wong's site, and he lent that tutorial to Randy at Anglers Pro Shop...
You can use any fly tying bobbin, but the trick is to fill the spool with some lead putty to give it extra weight to spin nice tight wraps....
Loams
Nevermind the knots.....
:X Reefman is anti Land Rover??? Clearly you have never been in deep dark Africa. It's ok to not like them, but you cannot be anti them. There is nothing.... and I will repeat this, NOTHING that I will take into the bush other than a Landy. That's because nothing comes close!!
Reefer, that's it bru, you off the xmas card list :headb:swear
Ya well what can I say.... Toriums, L#$%drovers, what next.... BMW's... :puke Hahhaha
You okes are way toooo sensitive! LOL....
Loamsie... been 4x4ing in Southern Africa the last 30 years... L$%&rovers are ok... they cope... sometimes... heheheh
Yup. Miss Daisy and me, we just cruise around towing caravans up Dunes in Swakopmund in a little 5.7l V8 Hemi.
attachment.php
Hooked
hemi-
A prefix meaning "half," as in hemisphere, half a sphere
Or half of a real 4x4;)as in 2x2
What do you call a jeep at the top of a dune
A miracle
Did you know that 90% or all the different jeeps ever built are still on the road?
the other 10% made it home
Nepptune
Reefer - I never knew you were a Sandton Soccer Mom/Seapoint Kugel...... cause only they drive those Us built excuses for 4x4's.....
By the way, don't you damage your susupension carrying around that Vault filled with all the cash you must need at the petrol station to keep that thing running.... I suppose its an automatic too????
attachment.php
The tag on this pic should have read SLY 702 GP...I agree with reefer here..land rovers are kak..they get you into the bush but cant get you out..for the true enthusiast,just like me will not settle for anything less than a big toyota landcruiser with the 4.5lt diesal motor!
Excuse for a 4x4?? You're confused my friend... It's got the most sophisticated 4x4 system ever developed.... stuff that bmw/landrover haven't even thought of yet. You WISH your little disco poncemobile could go where that Jeep has been...:spite
Yep, it's REAL HEAVY on juice, like a truck!:shock: But pulls the family and a 4x4 trailer fully packed at 180km/h no problem.
Read Andrew St Pierre Whyte's write-up after reviewing the Grand Cherokee... He was gobsmacked at what it could do... called it unstoppable... and there you have it... from the guru himself. Ek se niks nie!
Hooked
Mr Assassin and Mr Reefman
Anytime you feel like being towed , please feel free to give me a call
Hooked, I'm not comfortable in doing JHB to Sodwana in 9 hrs... rather do it in 4, and in style too. Don't have to pee blood when I get out the other side either.
Ay and who cares about gas when you got specs like this....
The Jeep Grand Cherokee SRT8 is powered by a hot-rodded version of the 5.7-litre Chrysler Hemi engine, bored out to 6.1 liters and churning out a claimed 310kW and 560Nm of torque. Jeep claims a time of 0-100km/h in less than 4.5 seconds and 0-160km/h-0 in a little more than 18 seconds.
Now how would that look, a SUV killing most street performance cars robot to robot?
You okes can carry on just wishing...!
