My steering pump on my boat is a Sea Star. I don't know what make cylinder is but I believe it is a locally manufacted stainless steel one that is used on most Tom Cats.
In December I changed the seals due to some leakage out the cylinder and the steering seemed fine.
Two days ago I got on the boat and the stearing would work for half a dozen lock to lock and then just start slipping, a slight push on the motor in the direction of turn would activate the steering and it would work for half a dozen turns and then start sliping again.
I was sure it was the a pump problem and removed the helm and took it to a power steering repairer.
They tested it on a work bench and the steering tested to 5 bar no problem.
I then opened the cylinder and flushed the whole system with parifin.
Alot of dirty steering fluid came out and we cleaned it until only clean parifin was being flushed.
I changed the seals and primed system with clean sreering fluid. the system was also properly bled.
The roblem has not been resolved.
Steering works fine for +/- 10 full turns and then starts slipping on full lock.
Anybody know what might be the problem.
