Nuki
I didn't see anyone suggesting you put the brakes in. I would suggest 1 red and 1 white brake block and then cast as it will minimise your overwinds by a huge margin.
The reason for overwinds is not reeling you line in properly like Ajay said. Also when winding one the line , wind it the same way it comes off the spool. If you wind it the opposite way , the line will act as a spring and jump off and not peel off. That will contribute to your birds nests. I have 2 GW 30 Daiwa's the one reel has 2 white brake blocks in and the other has 2 red. the reason for the 2 red is that, that reels side plate broke and i patch it till the new part arrives, so i got overwind after overwind, then i put 2 red brake blocks in and problem solved. You can also throw harder because the brakes slows down the spool. I only stop the reel when the sinker is close to hitting the water.
Also see that at night you throw better maybe even further because you can't see the sinker , u watching the spool and braking it before the overwinds occur.
