Power Swivels sucks!!!
Stapies
Hello Guys,
I am rather annoyed typing this. Went fishing today, slided out a bonnie and 5 min later my rod was flat and screaming like a 2 year old! Set my 22/0 circle and the dancing games began... Not too long in and mr sharky goes all bananas and breaks my steel right against my swivel. 200lb steel... Eish okay.
Took my slide of the line, made another cast and this time 400lb steel... Lets see if this will break. Now I am using the following...
365 G400 T53 8+1 - Super Mandril,
Avet Lever drag Raptor HXW 5/2
Steel wind on 160lb
2.4mm slide wit a huge power swivel
400lb steel and a 22/0 circle
Put a bonnie head in, shake, put the rod down and turn around. About 30 seconds and plat goes the rod with it screaming off like a mad thing. Decent shark, no jumping ans swimming quite fast. Fight it til it was quite near the side and I could feel it toying with me! Then hanging still and then spinning. Next thing slack! WTF!!! Really!
Reel in only to find the power swivel broke...
Eish now I think I must remove the swivel from all my slides!
How many fake place make "power" swivels and are they really all that much stronger?
I am upset, I know all sharks cant be landed or get near the side. Point is in the past small power swivels gave in, now we use the big kahunas and they part... I feel it is a weak spot! Shark was not too big either.
What is there to do?
willem wikkel spies
kry net die regte swivels.
ek dink dat dit is n verswakkings punt in die arsenaal.
maar verstaan dat dit daar moet wees.
ds daai vrydag middag batch.
die vraag is, kan jy dit op land toets, deur hard op die swivel te trek.
dan dit waag om dieselfde swivels te gebruik, wat jy dalk seer gemaak het.
Trophy
Hiya Stapies,
The only swivel that should go onto the boom of a slide is the KingFisher Japan Black Swivel #1 and 1/0 .
There are a lot of fake Power Swivels on the market!
