Power Pro Braid
Exavier
Hi,
Ive bought 500yd 50lb power pro braid from e-bay, cost R337.00.
Can any1 tell me if this is a good quality braid, and what the diameter is on 50lb?
I dont think i paid to much do you?:D
Exavier
TP,
Thanx, that was interresting reading...
Im a bit worried about the diameter, dont think it will come close to suffix(.17). Will let you know what its like. Will do a test as well. I work in a lab and have top of the range equipment to test braid. Thanx again.
Torpedo Jack
Ex,
Pleased the info could help. Now pray tell, what kind of lab do you work in? We on Sealine need to abuse you and your facilities :temp:to test out all Reefer's knots & rigs. Hope you can help us.
Mike
Exavier
HeHeHe... I should have known! I have tested knots in the past and reefman is spot on!! He is a knot fundi. We use a mashine that we do elasticity tests on. Basicaly its a machine pulling at 2 end and giving a set amount of pull in a set time. Eg. 1lb every 7 seconds up to 72lb. Its calibrated and accurate upto .0001g. Perfect if u ask me, they should of called the thing a "braid test 101". Thinking about it you will be able to have a reading in the stretch of your braid aswell. Should be interesting.
Simen
When talking to Mr Henn at the ESA show, Mark had this line on one of his boat rods. ( the grinder rig which they caught the Tuna on in the Cape ) It was a yellow line and it was like wax coated. They were going to import these lines.Talked very highly of it. Dont know much more try it and let us know.
Manta
Banned
Hey X
You have top stuff there!! Power Pro braid is just as good as Suffix, the diameter differs however. Its also price competitive. I have it on my workhorse SL50, best braid investment I reckon.
Its also available locally, was then when I got it.
Manta:cool:
Jasper
I have also bought Power Pro .. 500m of 50lb via e-Bay ... paid under R300 (inclusive of shipping) - so far I am very happy with it.
I am using it as my main line, my first time using braid and am AMAZED at how much I can now feel! I'm sure you can tell if a fish even looks at your bait!!!!!
It has also added about 20m to my casting distance!
christodeb
Hi Exavier i spooled my torium 50 with power pro braid. According to the power pro website the thickness is 0.014" or 0.35mm, i'm not to sure if that is true. I got 300m of 0.55mm mono on my torium with 1250m of 50lb power pro. Compare that to the amount of line the guys fit on their tor/trini 50's with whiplash as backing, according to Noweeds he got 1200m of whiplash and 300m of 0.55, therefore power pro could not be 0.35mm or whiplash is not 0.17mm
Just my 2c
Exavier
Thanx guys, sounds like a good investment. Reefman, Kathu is in the northern cape(Kalahari, close to Upington). If u guys ever looking for good hunting pm me and i will be glad to assist.
Simen, im still waiting to recieve the braid. Will let you know as soo n as i recieved it. I will place a forum on the test. Thanx again to all, you have been very helpfull.
