Poppers
Muffin Man
Alan and myself recently caught plenty Leervis on the white Seal point plugs changing to broader ones in choppy conditions and slim ones in glassy conditions. My best tally for one day was 21 fish landed and Alans 11. This excludes fish dropped and the numerous explosive chases. The biggest fish was 102cm caught by Alan. Alan with his 102cm fish.
Muffin Man
Me with a fish of 90cm. All fish were caught using single hooks and all safely released.
Patrick
Yo Mr Anderson, welcome back on SL... I must pick your brains sometime about this success with the leeries. I see these werent taken off the banks as per usual. I've noticed the bigger leeries seem to be landed from boats? Maybe chat about it sometime over a green windy corner at mahogany reef at the tail comp?
HappyPeople
Thats some really good leerie fishing, and well done on the safe releases. I also prefer using single hooks on the seal point plugs- makes for a much easier and safer release. My opinion the best swimming action in a plug i have seen- one may raise more strikes with a predator plug for example but as far as hook-ups are concerned the Seal Points really do the trick. Cheers
Bushbuck
Hi Guys
a Seal point plug, is that those simple chiszel nose plugs, the cheap ones that are made of nylon and have lead poured in the back.
I have been using the smallest ones and been shaping well with them. Nothing beg yet tho. What size are u using.
Others that i have has a lot of success with is a lure called a Sammy, used normally for bass but u can walk the dog, skim it along the top or fish it slowly. Only thing is its a bit light and doesnt fish that well when there is a chop on the water.
PimpYoda
Guys, I'm currently in the UK with the Weskus saltwater still pumping through my veins. The Sea Bass season is approaching on this side and I have spent a lot of time researching and reviewing the best lures on the International market at present. If you have spare cash to burn, take a look at these lures – they are deadly and will work well for Cob, Elf and Leeries in SA. A bit pricy but the quality is second to none.
IMA Sasuke 140
Xorus Patchinko 2
Yo-Zuri Mag popper Yo-Zuro Cristal Minnow Floating
Yo-Zuro Cristal Minnow Sinking
Rapala J11
Storm Lures
Ulua
Muffin Man wrote:
In rivers along drop offs where a long cast is not required you can try all the Rapala skitter pops or skitter walks, chug bugs they all work. I fish the areas that you have mentioned and after lots of experimenting in a river (Breede) my favourite plug is a 3/4 ounce tapered chizelnose made by Wayne (Seal Point) I will go up to a 1 ounce or even 1,5 ounce depending on the wind. With an 8ft spinning setup and a 4000 reel with braid you can cast all day and it will be more than sufficient to handle any Leervis hooked in this area.
I dont agree with what the one chap said that you need to see bait fish being chased before wanting to throw surface lures. Sure it does help if you see this activity but most of the fish I have taken in rivers is just by fishing certain areas on different tides therefore anticipating their movement with the tide. Most of the time we are just working drop offs and a fish or a shoal will come up behind your plug and turn them on.
In the sea I normally throw 2 ounce or 3 ounce plugs as generally I need to get more distance. Again the Seal Point are what I mainly use but the broader one. These new Bimini Plugs are also good. I caught well on them last year in the Transkei when I was given some as samples. I just yesterday bought some of their pink coloured ones to try out next week in the Transkei. In a nut shell the nylon chizel nosed plugs will catch just as many fish if not more than all the other fancy plugs. They cast like bullets and are half and sometimes even a third of the price. Cheers Paul
Ps. If you do a search I have done an article on catching Leervis at the Breede it should help with anything you need to know.
Very long ago topic! But are the Bimini Plugs still around who were they made by?
flippy
i see the Kingfisher Chaos plugs been doing well in Angola for leathers and bluefish.. well priced at Sportsmans Warehouse who can be more expensive than other shops for same product.. no offense
nice color range.. white/pink/glow etc and good size range
anyone try them locally? should work
die spook
Ek hou baie van my Heddon Chug n Spook kunsaas. Dis n kruis tussen n popper en n hodjieloop aas. Oneglooflike aksie.
