Popped up - how high
When using pop-up rigs, how high do you prefer to pop the bait up?
  • 1cm off the bottom
    Votes: 0 0.0%
  • 5cm off the bottom
    Votes: 0 0.0%
  • 10cm off the bottom
    Votes: 0 0.0%
  • higher than 10cm
    Votes: 0 0.0%
  • Total voters
    0
schelton
For what it's worth, in my opinion 1cm. Just off  the bottom, I know that some guys in the UK go higher, but I wouldn't.
My 1c.
J
I generally only pop up when fishing in soft silt or short grass and then the height I pop up depends on the depth of the silt or height of the grass, mostly I wouldnt go more than 5cm but have popped up as high as 30cm before with success.
momo330
i once,just out of curiosity fished an 18mm pop-up,popped up 5cm on a clean flat bottom and had a fish.....makes you wonder :)
KUSAF
Hannes I wouldnt say anything higher than 5m is a zig rig. Ive had success on a chod rig up to 25cm and then also I like to make combi links of about 7cm silkworm and pin it at the joint with the fluorocarbon.
The length all depends on the venue for me. but as arule I would go for 5-7cm and work from there.
I think another good question would be are you fishing popups or artificial baits on your pop-up rigs. I love a bright coloured artificial 15mm when fishing a chod.
MadCarper
I read a very interesting article awhile back about pop-ups. The author believes that because most big carp are deep-bodied (rugby ball shaped), it would be easier for them to suck in a pop-up that is presented about 15-20cm off the bottom (meaning that the fish will be in its normal "upright" position when approaching the pop-up) than it would be for the carp to have to tilt its body 45 degrees first to eat the bait off the bottom....
I gotta be honest I havent used anything popped up higher than 5cm, so wonder how true the above is... I have heard of some guys fishing 15cm off the bottom to take advantage of the above theory and they got some pretty big carp...interesting...
Basspro
As high as U want - 1cm to 1 ft -- that's how I had my big one ---
Irrespective boilie size U can experiment - that's best me thinks !!!
