Nope not very much .
Poly was always a better boat reel (trolling) than a casting reel . That said, its the easiest multiplier reel to learn ,to cast.
The way the drag system works .Will always leave some friction on the spool .The result being that it never turn as freely ,as any other reel and in particular any other lever drag reel.
This result in the person not having to worried about any over winds.The negative side of this is that one will not reach the casting distance, as with normal multipliers.
The only other model lever drag reel. That had this capability . Was the Daiwa LD 50 . Although the spool would turn completely free as a TLD 15 would. It had a set knob on the left side plate for casting purpose .
The Poly was at one stage a very affordable reel to buy . The other models it competed with was all much more costly to buy.
Currently the price of a Poly got so high . That I will never buy a new one . Most other better reels will now only be a very small amount more costly .
Like you said .If looked after (Poly is high maintenance reel) it a bullet proof reel and can last for years !!!
We had 4B Poly's on a commercial boat for some 4 years. Catching tons of King Mackerel , Queen Mackerel and tuna , before they had to be replaced.
This was only needed as with the owner not doing regular maintenance on them . They actually rusted (corroded) to pieces . One of their main problems is corrosion .They tend to corrode just where the stainless screws and aluminium frame meet .
This is also a problem with any other aluminium framed reels.
