Regarding the Rod, there is a big difference between the 9ft and 10ft vengeance. The 9 feels awesome (for the price), but the 10ft feels very bulky. If you really want a 10ft for R400, get the Megaforce (it also feels bulky and dead, but it's a little better). You'll have a much wider selection of way better feeling rods in the R600 - R700 class.
Regarding the Regal, make sure you get the 5i model (Rated for saltwater) else it won't wear well. Got my 5i for R299, very good value for money, just service it regularly and pack the open bearings of the crank handle with grease regularly and it will serve you well.
Fireline is an awesome CASTING BRAID! Just don't get 20lb, it's much heavier than the rest of the tackle you described. With the gear you mentioned, I wouldn't go heavier than 15lb (The Regal's drag will slip at about 5kg anyway, so you won't break off). Casting braid has a coating on the line to make it thicker causing less overwinds, also makes it more hard wearing and more slippery though the eyes of your rod. All of this gives you more distance and doesn't wear the line out so quickly when you do a lot of spinning.
Guys who likes shimano doesn't like casting braid because shimano (although it has good mechanics) has terrible line capacity and you usually end up buying your reels one or one and a half sizes to heavey just for the line capacity (Which sucks for spinning!)
