Please Help
SUNSHINE
Hi guys.
Im thinking about making some surface poppers from wood. They will be used to target Garrick in the EC rivers and maybe some surf.
The posts here have helped me alot, the only thing I cant seem to find is how do you seal the wooden poppers? Mainly the inside where you run the wire through.
Also what drill bit do you use to drill the popper for the wire?
Thanks guys.
Looking to get one like this on my homemade poppers and plugs.
tauruck
Long drills are available at speciality tool stores.
To seal the wood use Polyester spray filler. It's easy to sand etc when dry.
If you don't have a lathe I know someone in PE that would help.
Just saw you want to seal the cavity. Pour resin down it.
Just don't seal it. None of mine are other than the outside with a ton of paint. I don't use any filler on my poppers, sand by hand till smoooooth and paint.
tauruck
The guy was asking about filling the core where the wire goes through the lure.
His wooden lures will vrot van binne if the untreated wood is exposed to water IMO but then he has to make up his mind which way to go.
I got that!
How do you seal the inside of your poppers? I got plenty poppers here, my stuff and others and a few "imports"... none are sealed on the inside. I'll cut one open tonight. It's gona hurt!
tackle whore
yep checked 38 poppers and stickbaits none are sealed internally not even the 14 layer ones . i pour clear coat down the centre once i start painting the final clear coats on , else submerge in sanding sealer for a minute . its going to take a whole day of nonstop casting to get a wood lure waterlogged and from the pic if you do a chiselnose plug, it wont really matter as you retreaving the lure not relying on its natural bouyancy such as a stickbait
