Please can one of the guru's help. I had 4 x tanks original Hondas with fittings. I am switching to 4 x 25lt square tanks with valved cap and. They will all fit into a single compartment, the 4 I had I had to store 2 separate as they do not fit.
I have 2 lines from the compartment one for each motor.
I need to couple 2 tanks together, preferably with a switch / valve so I can choose which tank per motor. What is the best / simplest inexpensive way of doing this?
Thanks guys
Thanks guys
Barry sorry couldn't help but ask just to see your reaction. Glad to see that you are able to use your boat at long last. I hope you only have enjoyment ahead of you now.
