van_straaten wrote:
Wow not one possitive.
I prefer fluorocarbon the whole trace is only 45cm long
The whole point of this rig is to keep to platie from diging under rocks and debris.
also to keep fillet/platie of the bottom away from crabs
but thanks for the input
Results to follow in 2 weeks
From above seems like you want to rig the plattie live. Not wanting to get into legalities regarding this, here is the way I use to do it when I still used platties.
Hook the plattie through one thigh(Bo been). Now take a syringe draw some air into it and inject the air under the skin on the lower back.
The plattie will try to get under structure on the bottom but will keep popping up due to the air bubble.
As the other posts I also do not like fluorocarbon, expensive, hard and not needed for barbel. I use Maxima Ultra green. Abrasive resistance is the main reason for my choice.
I would also not use the cork. Unless it is fixed it may interfere with the kook set if it moves down to the hook, and not really needed. As long as there is some flow in the water, this will lift the bait of the ground slighty.(even in deep holes).
With such a big hole available, I would do my best to get a muddie and fish that on a breakaway sinker rig. My favorite bait for big cats and it is guaranteed to get you a decent fish.
As F1%hpa%te mentioned each person has his own rigs and tricks.
Hope this helps some and good luck, please post the pi's of the big one!
