:fishn
Just the idea of this... I will never be able to bring myself to do this! Gril...I sometimes take a tampon and cut it in 5mm strips. Let it soak in anchovy oil for 30 minutes and then tie it to the hook, then cover it with a well tenderised tjokka !!:fishn
Used or new?I sometimes take a tampon and cut it in 5mm strips. Let it soak in anchovy oil for 30 minutes and then tie it to the hook, then cover it with a well tenderised tjokka !!:fishn
USED for sharks and NEW for edibles......hunter1924 wrote:Used or new?I sometimes take a tampon and cut it in 5mm strips. Let it soak in anchovy oil for 30 minutes and then tie it to the hook, then cover it with a well tenderised tjokka !!:fishn
I suppose one could slide the JUMBO XXL ones.....:shaRedEye wrote:USED for sharks and NEW for edibles......hunter1924 wrote:Used or new?I sometimes take a tampon and cut it in 5mm strips. Let it soak in anchovy oil for 30 minutes and then tie it to the hook, then cover it with a well tenderised tjokka !!:fishn
That's not right.RedEye wrote:USED for sharks and NEW for edibles......hunter1924 wrote:Used or new?I sometimes take a tampon and cut it in 5mm strips. Let it soak in anchovy oil for 30 minutes and then tie it to the hook, then cover it with a well tenderised tjokka !!:fishn
Julle siek bliksems....lolRedEye wrote:USED for sharks and NEW for edibles......hunter1924 wrote:Used or new?I sometimes take a tampon and cut it in 5mm strips. Let it soak in anchovy oil for 30 minutes and then tie it to the hook, then cover it with a well tenderised tjokka !!:fishn
